New ktlcd3 and controller
Parsons
193
13
50
Hi guys as you know from my other post I knackered up and lcd3 display. which would not match my old controller . I have a new one with matching sim wave controller all working fine . But need a little more help with c2 setting something to do with phase and magnets 0 to 7 on the settings all I know my rear hub wheel is 1000w . 3 phase and hall sensor don't know how many magnets can you help thanks
8,230
On all my hubs C2 is 0 if I try other values they run rough.
Try value 0 and if your hub is ok leave it alone other wise try all 8 values but don't use the throttle to test as full amps may cause damage with wrong value, always use PAS for testing drive and once you are happy with the hubs running in upper PAS levels you can use throttle.
8,230
