Today I passed the one thousand kilometer mark. The ride was especially chosen for this milestone with lots (LOTS!) of hills and some fabulous scenery.
As an apetiser I rode the usual 11 k to the station. First course: from Zumaia to Deba is basically a climb to 260 metres that is about 10 km long followed by a 6 km descent with a stretch at 7%. Then main course... More steep hills.
But shorter
I did some checking out of bars (from the outside!) and other important stuff like beaches etc. for when I go back with SWMBO. In Mitriku I went down to the port. On the way down I thought "you are never going to ride out of here" and effectively I pushed the bike all the way back to the top. Cool trick, I pushed the bike back up cobbled pedestrian streets to make it look like I was doing it on purpose
25+ kilometers there so 25+ kilometers back
When I got back to the station in Zumaia I still had 35 volts showing on the LCD but I have learned that one does not go far on 35 V. So a total ride of 65 km or so with mostly ups (long) and downs (long too).
I tested the speed accuracy of the LCD the other day with my GPS. It seems to be almost spot on. A little mystery surrounds top speed - 58.4 on the LCD and 60.49 on the GPS but the averages are identical. And life is all about averages is it not?
Conclusions after 1,000 K? I love it! I need more Amp hours, a cheap no name battery capable of doing another 40 km at 20 kph average would do the trick. https://bmsbattery.com/ebike-battery/571-36v10ah-right-off-bottle-battery-pack-with-charger-battery.html with the controller in the base, I am still allergic to wires everywhere. My Samsung cells would be transfered to the same type of case. I need a new bottom bracket, tricky, the current one is epoxy glued into the frame...
I have all the bits to upgrade the crankset etc. to lovely Shimano aluminium instead of plastic. This months investments are lights - the days are getting shorter, plastic pedals - I have had enough of cutting my shins on MTB metal ones.
The on to the Mk II pedelec build!
But shorter
