I have had an intermittent problem from the start with the battery charger I got with my ProConnect two and a half years ago.
When I took the battery off the bike and put it on the charger sometimes it wouldn't start.
At first I replaced the fuse in the plug. It worked, but then a few days later it wouldn't. I then found if I just opened the plug and then closed it up again it would work.
I have followed this procedure all this time whenever the problem recurred. I must have opened and closed the plug a hundred times.
Recently the charger didn't start again but I had to leave the battery on the charger until I returned. When I got back I switched the charger on without opening the plug and it worked.
When it happened again I just left the battery sitting on the charger for ten minutes then switched it on and it worked.
It has continued to work in this way since.
Can anyone explain why it does this?
