I am trying to build a PAS on my ebike which uses a VESC controller. I stumbled upon two great projects by
www.pedelecs.co.uk
Both of them seem to fit my needs but unfortunately I don't understand German. The first project is a fork of the second and works on a Teensy controller and uses a color display.
I feel teensy is a bit expensive. Can I use it on a ESP32? If not, how do I modify it to work on a ESP32 or similar mcu.
The post states the battery capacity,voltage, speed,etc are taken from VESC, does the VESC read battery capacity, voltage, etc?
Andy!
GSM middrive, with VESC and Teensy "ForumsController" conversion
So, my latest build is finally mostly complete: I used for the build a GSM middrive (without internal controller) from Woosh, a VESC open source controller and a Teensy as "CycleAnalyst/ForumsController". I have built a display based on a 2.2 inch LCD and also module with 5 way joystick for the...
elfkw-Umbau mit programmierbarem Arduino-Controller
Ziel war ein unauffälliger, legaler Pedelec-Umbau für den Arbeitsweg (2x9km, 140 Höhenmeter). Nach einem Umweg über einen GM Magic Pie bin ich bei elfkw gelandet und sehr zufrieden. Nur die Pedalsensorsteuerung war mit dem Standard-Elfkw-Controller (kein MMC) nicht zufriedenstellend (siehe...
www.pedelecforum.de
Andy!
