I have had some punctures in Schwalbe CXCOMP and then Marathon Racer tyres. It really does depend on your usage and route. I have recently switched to Schwalbe Marathon Plus and this seems to be the tyre best suited to my usage and route. I dont carry a spare tube. Nearly all my punctures have been fixed without removing the wheel using a "safety pin method"What tyres are you using Hoppy?
I have just ordered the Enduro and am looking for road Schwalbe tyres which will fit it. As soon as it arrives I will change the tyres.
I have 3 bikes and always use Schwalbe and have never had a flat. Touch wood.
Steve
OK Alan......spit it out ......what on earth is a safety pin method ???I have had some punctures in Schwalbe CXCOMP and then Marathon Racer tyres. It really does depend on your usage and route. I have recently switched to Schwalbe Marathon Plus and this seems to be the tyre best suited to my usage and route. I dont carry a spare tube. Nearly all my punctures have been fixed without removing the wheel using a "safety pin method"
Yeah, i'll bite too... please explain the 'safety pin' method.OK Alan......spit it out ......what on earth is a safety pin method ???
z0mb13e/Funkylyn, This is for those small to tiny punctures and goes as follows: pump the type up to full pressure, find where the air is escaping using you preferred method, determine if there is something in the tyre and remove using a sharp object i.e a safety pin (for me its usually shark tooth flint) and then ... and this is the clever bit ... puncture the tyre MORE by stabbing it with the safety pin. A single stab will suffice. The tyre will then deflate quickly. Reveal the tube using your plastic spoon things .. and then inspect the tube and find (without any trouble at all) the nice hole that you made and patch it. (No need to re-inflate) -- I usually get one of two responses when I explain this method. I wonder what yours is going to be?Yeah, i'll bite too... please explain the 'safety pin' method.
Well I've been flitting backwards and forwards between confusion and incredulity but I think I understand now. You are making the puncture in the inner tube more obvious so you can find it easily... am I right? But not sure about the 'no need to re-inflate' I must be missing something there... I had visions of some clever fold in the inner tube held firm by a safety pin!z0mb13e/Funkylyn, This is for those small to tiny punctures and goes as follows: pump the type up to full pressure, find where the air is escaping using you preferred method, determine if there is something in the tyre and remove using a sharp object i.e a safety pin (for me its usually shark tooth flint) and then ... and this is the clever bit ... puncture the tyre MORE by stabbing it with the safety pin. A single stab will suffice. The tyre will then deflate quickly. Reveal the tube using your plastic spoon things .. and then inspect the tube and find (without any trouble at all) the nice hole that you made and patch it. (No need to re-inflate) -- I usually get one of two responses when I explain this method. I wonder what yours is going to be?
This is road side or lunchtime at work. Having found the hole in the tyre and removed flint you deflate and reveal the tube only to find that you cant find the hole! ... so .. I used to re-inflate in order to find the hole that I know is there somewhere .. and sometimes even after re-inflating I haven't been able to find the hole ..(bear in mind that I am in my 50s and spent 2 years in my reading glass denial phase! ..)You are making the puncture in the inner tube more obvious so you can find it easily... am I right? But not sure about the 'no need to re-inflate' I must be missing something ...
All makes perfect sense! One to remember.This is road side or lunchtime at work. Having found the hole in the tyre and removed flint you deflate and reveal the tube only to find that you cant find the hole! ... so .. I used to re-inflate in order to find the hole that I know is there somewhere .. and sometimes even after re-inflating I haven't been able to find the hole ..(bear in mind that I am in my 50s and spent 2 years in my reading glass denial phase! ..)
Very clever......AND I understood it......which is amazing as I have to admit that I (whispering )have never fixed a puncture in my life ........but I am going to learn and will remember your clever tip.z0mb13e/Funkylyn, This is for those small to tiny punctures and goes as follows: pump the type up to full pressure, find where the air is escaping using you preferred method, determine if there is something in the tyre and remove using a sharp object i.e a safety pin (for me its usually shark tooth flint) and then ... and this is the clever bit ... puncture the tyre MORE by stabbing it with the safety pin. A single stab will suffice. The tyre will then deflate quickly. Reveal the tube using your plastic spoon things .. and then inspect the tube and find (without any trouble at all) the nice hole that you made and patch it. (No need to re-inflate) -- I usually get one of two responses when I explain this method. I wonder what yours is going to be?
Brilliant - thanks for heads up - its certainly an advantage.Went to go for my daily ride only to find rear tyre flat! But discovered another advantage of central drive system-no need to undo any electrical connections-qd wheel comes out as easily as an ordinary bike.Quick repair and away!Shall carry spare tube now
Steve
