G
Ghost1951
The thing about Trump is that he just makes stuff up and asserts it, as if it was true. It is like he thought he could make anything up and make it be true. I know a guy like that who is known around here as 'Zachariah the Liar'. His son told me, ''You always know when my dad is lying, because his mouth is moving.'
A guy like Comey is FAR too smart to do something stupid like post a gangster meme threatening Trump - even as a joke, if he knew what it meant. Anyway - why would people of that social and educational class be familiar with 'gangsta' memes? But Trump goes on national TV ans asserts all that cr ap and people treat him seriously. There is no grand plan with him. He gets an urge and does it or says it like a three year old would. He is obsessed with grudges and getting even.
As for the other one - Biden - he is completely senile and pretty much a dribbling wretch. The fact that the Democrats ever put him up for a second term is an absolute disgrace and an insult to the American People. The fact that so many of the big Democrat beasts were still talking him up after the debate fiasco is beyond imagining. The whole political system there is utterly corrupted. There never were in my memory two worse candidates than the two that were put up and even when Biden was finally winkled out of the race, his stand in was hopelessly weak, and of course the taint of the Democrats having stood behind a senile man while saying he was fine, was not going to be forgotten by voters and added to Harris's woes. They knew they could not trust them after they had so obviously tried to foist a dotard on them.
EDIT:
I am also very surprised that the secret service went to see Comey. The country is getting more like Tudor England where a paranoid lunatic - Henry V!!! was pursuing grudges and mad suspicions and all the apparatus of the state enabled him and did his bidding.
Probably the architecture, too many steel beams?
No, traditional brick structure, but in a steep sided valley with signal masking and a every attempt at repeaters failing due to bad surveying/ poor positioning.
17,428
EDIT:
I don't think Biden is senile. His symptoms look like Parkinson's.
G
Ghost1951
He doesn't have Parkinson's symptoms. Look them up. Those are not what he has. He has serious cognitive problems. These made him ENTIRELY unfit to be President with all of the power and responsibility involved. Watch this clip of his unravelling in the debate with Trump.
Whatever it is that makes him fail so badly in that debate - especially at the end where he just unravels completely, whatever it is, it makes him absolutely incapable of performing that role.
6,733
bindoo did that :oops:
6,733
17,428
I had a close relative with parkinson's and depression. Those two diseases go together sometimes. I thought Biden has symptoms of someone who takes lithium.
Symptoms of parkinson's include torpor and inertia.
Nick Robinson interviewed Biden: you can listen on bbc Sound
Article:
https://www.bbc.co.uk/news/articles/c89g491e8ewo
baz1975
11
Anybody know where the ECU is located on the Apollo phase? It's in for repair and Halfords can't locate it in desperate need for help thanks
17,428
By ECU, you mean what we call the controller? It's inside the base of the battery.
17,428
Did they open it? Just follow tge cables.
17,428
No idea but they've had it for nearly 2 weeks, is it in the battery cage?
Yes. Trace the motor cable towards the battery.
baz1975
11
The
battery is working fine they have tested it on another bike,
They have tested the battery that works fine as well as the handle bar display and the bike still won't function, it's crazy they can't find it as it's Halfords own brand
17,428
Ask them to change the battery cage.
The controller is not inside the battery. The battery contact at the base of the cage has two pins. The controller is inside the base, under the two pins.
G
Ghost1951
I'm no expert, but I'd be wondering of the pedal assist sensor was working, given what the OP says. Battery works on another bike - check. Handlebar display works - check. Bike not starting..... I'd look down at the PAS sensor.
By the way - if the so called experts at Halfords were calling the controller the ' ECU', that's a bad sign too. Nobody qualified to diagnose the problem would be calling it that.
Just my six pennyworth as a layman.
