Wow! This motor rocks. I'm using the 201 rpm 36v version at 48v. I wasn't sure how much current to use, so I thought I'd start with only 15 amps. I made a mistake in trying to pedal away on level 5 because it made the front wheel jump up in the air. I went straight to my 14% test hill to test it's torque. It had no problem pulling me up without pedalling (all up weight about 109kg). Top speed unloaded is 29 mph, which is a bit faster than what I wanted. I didn't change anything else on my bike - still the same 48v Dolphin battery. The controller is from Kunteng, the same as the S06S from BMSBattery but 48v. On the road, it seems to have really good power throughout it's speed range way past 20 mph.
If you want a fast commuter without the weight of a massive battery and hub-motor, this motor on a good lightweight hybrid like the Boardman would work really well. It would also be good if you're a bit lardy and want to do a road-bike conversion. If you wanted the slower pace of an MTB, the 36v one would be better with increased current - say 20 amps for a top speed of about 19 mph on the road.
I must say that it's nice to have my 9-speed gears back after all these years - and that nice Shimano XT slick-shifting.
The bike looks exactly the same as before:
