I took advantage of the Ebike testing day at Redbridge Cycle Track on Sunday, to compare the performance on my crank driven Kalkhoff Agattu with that of some of the bikes with rear hub motors. I was particularly interested to see how the hub motored bikes coped with the short 10.5% hill.
Here is the circuit with plots of the tracks recorded by my GPS.
The underlying map with the 0.5 m interval contours I took from the planning application for the site. They obviously built parts of the track in slightly different positions to that shown in the planning application, but I assume they did not move a lot of hillside so that the contours remain accurate.
The GPS tracks show a lateral scatter of about 5m. I actually rode much tighter set of paths than that were probably located over 1 to 2 m laterally. There is of course drift in the recorded GPS position by up to 5m as the satellite position and the ionosphere vary over timescales of a few minutes, and this accounts for the width of the bike tracks
I rode 8 large laps as follows:
Except for lap 2 on my Kalkhoff (which was as a result much slower on the hill), I used maximum assistance settings for each bike, and tried to judge the optimum gear setting to provide maximum extra propulsion from my pedalling.
Somewhat to my surprise there was very little difference in performance of the bikes on the steepest part of the hill - all except one managing around 10.5 to 11 mph. Of course I put in quite a bit of pedal power to try and keep the speed up, and this does make it impossible to do an exact comparison of the bikes. I only achieved 8.3 mph on the Kudos Tourer Deore-9. I don't think I was pedalling less hard or in the wrong gear so I suspect that the hill climbing of this bike may be slightly down on the others. I did only a single ride and I would really need further repeats to confirm this conclusion. Here is a plot of the GPS track when riding the Kudos Tourer Deore-9 with my Kalkhoff Agattu track for comparison. The red dots are the GPS position from my Garmin Etrex which I set to record every 2 seconds.
Comments on Folders
This was my first experience perched on folders with tiny 20 inch wheels. I noticed the steering seemed more "twitchy", but perhaps that is something one gets used to. I also noticed that when pedalling hard on the hills, the long front stems on both folders flexed - I wonder how long they would last if ridden hard. The two folders did not seem fast, but perhaps that was because they were set up for a high cadence, which does not suit me. What really surprised me when I went home and calculated their hill speed was that it was also 10.5 to 11 mph. During the ride I had been convinced that the folders felt slower.
The surface of the cycle track is very smooth, so I did not find out how the suspension of the folders would cope with a more normal rough and potholed road. There are off-road tracks at Redbridge, but I did not try them, since I was concentrating on hill climbing.
- My Kalkhoff Agattu -3 speed, in max assist (crank driven)
- My Kalkhoff Agattu -3 speed, in min assist (crank driven)
- Easy Motion Volt (folder - crank driven)
- Kudos Tourer Deore-9 (rear hub motor)
- Kudos Secret (folder) (rear hub motor)
- Easy Motion BNeo City (rear hub motor)
- Wisper 905SE (rear hub motor)
Comments on Folders
