7 gears could be a freewheel. Use Google to see pictures of the difference between freehub and freewheel gears, then look at your gears to see which one you have. Are you sure you have 7-speed. If you have, you can change to a frewheel system because your shifter and derailleur should still work for it.
A problem with freewheel gears is that the top gear tends to have too many teeth - normally 14T sometimes 13, and that is too low for when you want to pedal at 25km/hr a lot of the time. You need 11T top gear for more comfortable pedalling. Cassettes nearly always have 11T top gear. You can buy 11T freewheels from Aliexpress under the brand DNP, but they cost around 25 Euros. You don't need any tool to fit one, but you need a freewheel tool to get one off. The freewheel removal tool is very similar to the cassette tool, but the splines are different and the listings are never clear which one it is, as they use the wrong words in the description, so be careful. Ask us to check if you're unsure. The whole matter of freewheels and cassettes is very confusing for everyone, especially when you add in Chinese translations.
