OK - understood. That's definitely something to think about when evaluating the costs and effort.
Going right back full circle to where I started a few days ago, my original thoughts were to run 2/3 of the cheap ones as "low beam" wide flood near distance lamps. Then have a beam-up switch to turn on the CREE(s) for longer throw and brightness. There could be one or two of these brought on by circuit settings 2 and 3 all as sequential additions leaving the others on.
It all got derailed when it appeared that the cheap lights and the CREEs were running at different voltages so couldn't be hooked up to the same buck converter ... and more so when it then appeared the CREEs had the multimode which was going to over-complicate rigging up to a handlebar switch.
So, where we now seem to have got to is that there's an easy workaround for the single LED CREEs simply by using an AM7135 board in place of the usual CREE driver boards... but I am told quite clearly that these driver boards mustn't be used at a voltage exceeding 5A. The housing complications can be got round by using Marwi housings instead of trying to modify the usual magicshine-style housings. So far so good.
I think the point I'm taking from your experiment is that (as I suspected), it's a waste of money using CREEs for near-distance flood lighting. That accords with my own thinking !!! It's the longer throw power lighting I originally wanted to use T6s for.
(Hesitates) ... it the answer really very simple then - just get 2 high-powered CREE T6s to run at 5V, set them so as not to overload the current capacity of the relevant buck converter, and add in 2 x cheapie front ones + 1 x rear light in series which can run at 5V and use the remaining available current capacity of the 5V buck ?
... or even simpler maybe ...
1) 2 front cheapies + 1 rear (with diode
) to come on when the bike's turned on (and always be on) ... via a 12V buck if needs be ... plus ...
2) 2 CREEs in parallel off a separate circuit run at 5V to come on via my handlebar switch as supplementary lights (Off - ONE - BOTH settings as needed). I can run them both at up to 1.4A each if the buck / DC-DC converter can run 3A with no additional resistors / no mods to the current limiter chips on the standard replacement boards. Just fit and connect. Or so it seems... ?
Has what was unfeasibly complicated this morning now become relatively straightforward with exploring all the options ? Or have I missed a problem in my ever so hopeful "summing up" ?
