I've moved this from another thread to save going off topic.
The question was asked regarding range/battery capacity, isn't there a simple way of setting a standard means of measuring the ability/range of ebike's so the consumer can judge suitability. I came up with the following idea as a starting point, maybe some of you have similar or better idea's.
What about adapting a non powered running machine[bike drives track] with variable resistance.
It could be set to simulate say, flat terrain and an average weight rider using throttle power only to drive the rolling road at a set resistance, it would provide some measure of achievable range.
Using throttle power only, eliminates the complications of rider weight/input, gearing, terrain and wheel size, so could be applied to all type's of ebike's as an average measurement of ability.
In fact a small unit with two rollers at a set resistance under the driven wheel would suffice, you only need measure in time or distance. It may at least set some form of standard.
