No thermistor is needed John, they are only to protect against over-voltage charging with NiMh.
Your charger will be ok for the individual batteries only if it's one intended for SLA charging, otherwise I can't say on the information you've given, but it seems a bit inadequate for such a high capacity charging need as that whole assembly of packs. The charge would take a very long time indeed.
Tony Castles at Elecrodrive, 07974-723996 may be able to help with a suitable charger as he supplies some for his kits with SLAs.
