sla to another type of battery
avronb
97
This should be in the technical section but i cant get onto it for some reason,my question is,can i change from SLA to a lighter type of battery without damage to the motor/controller etc.,my bike is a Ezip Ezgo,i do know that i would need a new charger.
JuicyBike
1,671
527
Derbyshire
Two things must be the same about both batteries, volts and amps.
The maximum amp-age of the battery is different to the AH rating. It's the number of amps that can be drained at any moment, safely. A fuse should protect the battery, but will keep blowing if your bike demands too much from the new battery.
So, find out if your controller indicates what amps are drawn from the battery and then you'll have all the info you need. Or perhaps someone will be along shortly to tell you what the figures for your bike should be.
