Hello, I have seen in several posts in this forum that some users have their own DIY small LiFePO4 (and / or A123; I am not sure if A123 is LiFePO4 or not) batteries.
I am still defining which kind of e-bike I do need, but one clear possibility would be a Brompton with say a Q85 (or one of these tiny motors I also have seen in this forum, which I believe are not Nanos, but something even lighter, 1.2 kg).
However, when one looks at the usual Chinese suspects (Ping, BMSbattery, Greenbikekit, elifebike ...), LiFePO4 batteries are either 9 Ah or bigger.
But I believe for urban usage, one could cope with smaller batteries, especially if one is willing to pedal. And I want to pedal, I want to exercise. The reason for the motor is just to jump-start during the first say five minutes, and if some day I feel tired. But in general, I tend to believe my electricity consumption would be quite low. Also, probably I could charge at work.
I have seen tiny batteries, such as 1.1 Ah (18650 I believe) and 2.3 Ah (26650 I believe). I believe these small batteries are attractive for weight purposes (if they weight 1kg, a Ping 36V 10Ah weights 3.7kg, so 2.7kg saving; the Titanium package for a Brompton saves around 700g for a cost of several hundred pounds, for comparison purposes), and also, one could adapt the real battery needs over time in a more flexible way than with a big battery package.
The problem, of course, is that I do not know how to assemble everything. From what I have read, one needs a BMS / PCM to safe charge and distribute the current efficiently for all cells.
But then one DIY-er said that at least with some cells, even a BMS was not necessary.
http://www.pedelecs.co.uk/forum/electric-bicycles/8212-a123-batteries.html
And then I guess one needs connectors / other small pieces to make everything work.
Is it reasonable to assume that a person that does not know about this, could assemble his own DIY LiFePO4 small battery? Is there a "guide for dummies"?
Thanks!
Edit: I do not consider LiPo batteries for safety and number-of-cycle reasons.
Thanks!
