Sunrunner/Bronx on eBay
rooel
357
I discovered this on eBay:
SUNRUNNER/BRONX VERY LIGHT ELECTRIC BIKE. DIRECT TO YOU on eBay, also, Bikes, Cycling, Sporting Goods (end time 01-Nov-08 18:48:33 GMT)
and have found further details here:
BRONX SUNRUNNER 26" 2008 : £765.00 : ELECTRIC BIKES TRIKES AND SCOOTERS : Electric Bikes - Unisex -
Unfortunately the only information the eBay seller (an established cycle dealer) has available about the gearing is that the rear sprocket is 12 tooth (but can be changed) and the chain wheel is either 44 or 48 tooth. mailordercycles says the three speed hub gear is a Nexus but does not specify which version.
With its lightweight battery and claimed total weight of 19.5 kgs this bike appears to have some of the attributes of newer models now appearing, such as the Cytronex, small battery and lightweight, but requiring a fair amount of input from the rider much of the time (especially so, I should think, if the 35 mile range claimed for the Sunnrunner/Bronx is to be achieved from its 3.5 amp battery).
I have now found the manufacturer's site:
:: BRONX CYCLES 08 ::
and find there that both brakes are claimed to be V-brakes, while the eBay item has rear drum and front side pull. More interestingly the flyer which can be downloaded from the manufacturer's site describes ten levels of power assist which can be set on the controller, quite an advance on the Agattu's three levels, but the motor unit is definitely not Panasonic being a front hub which the manufacturers claim to be "unique" as it allows the bike to be pedalled normally without the power assistance!
keithhazel
997
the technical data is beyond my mind but i did like the "3 year warranty" bit...:)
30,855
The Bronx bit is a bit meaningless as these are the Sunrunner bikes previously handled by Hilderthorpe Cycle shop in Yorkshire. They use a tiny lithium iron (LiFePO4) battery sitting on the handlebars. Very short range and low powered with limited current into the Nano motor. A light bike, but not up to the Cytronex standards, though like all bikes with the Nano motor, there's no resistance to pedalling without power.
Mainstream manufacturers are refusing to adopt lithium-iron yet due to consistency problems and Sunrunner are the only ones seen with them so far. Therefore there's the "early adopter" risk and no certainty of getting replacement batteries in future with no properly established sole agent in this country.
rooel
357
The Nano motor information is interesting. With the delays in obtaining Nano motors from the appointed importers, and the apparent impossibility of importing them personally from China it could be worthwhile spending £519 to buy one of these eBay Sunnrunners, then discard the battery and fit a larger Lipo on the rear carrier.
30,855
Bear in mind though that Cytronex are said to be releasing a Nano kit sometime in the New Year.
rooel
357
Thanks, flett. I think a fully specified kit would be the best way to proceed.
