As I have said many times on this forum, I am a big fan of carrying only the battery size/weight that you need for a trip. My daily use (10 mile round trip commute) DIY battery weighs 1kg, 36V, 3.0AH and will give me around 15 miles albeit in flat Cambridge. I also have a DIY 2kg, 6AH battery. This is my lightest electric folding bike a Brompton M2L-X at 11.5kg excluding bag/battery.
Even if you had a longer commute of say 10 miles each way you could keep a charger at work.
The trick is to get the battery sizing right and to make sure you dont take it down below 1/3 charge to ensure it lasts you a few years. The beauty of the DIY battery route (not for all I know) is if a cell goes its easy and cheap to replace. I still have my original DIY battery which was used daily for over three years and has 6000 miles on it. Changed two cells in that time.
Of course using Lithium Polymer batteries is another alternative, but not advisable unless you are very confident in their safe use.
Regards
Jerry
