Tongxin 260rpm anyone have?
jerrysimon
3,292
112
Cambridge, UK
I have a few but I need them for spares :p
These people list and sell them, but you will need to be prepared to purchase and get them direct from China, with all the associtiated risks and communication problems.
Regards
Jerry
amigafan2003
1,389
139
I'd be interested in trying out a 260 rpm motor. Maybe we could organise some kind of group buy?
jerrysimon
3,292
112
Cambridge, UK
I am not sure it would be advisable to use a Tongxin 260RPM motor in any wheel larger than 20".
Regards
Jerry
amigafan2003
1,389
139
Regards
Jerry
Probably not advisable but I do like to experiment :)
It's not adviseable to run a Tongxin on 44v lipo at 17a either ;-P
jerrysimon
3,292
112
Cambridge, UK
My 12s A123 are not much below that fully charged at 43.2v and I been running it for 3000 miles and over two years. Is that fully charged ?
These motors can be fragile and don't take to being over volted or stressed well. I say not to put it in a larger rim as I assume (maybe mistakenly) that it will be trying to turn the wheel at a slower RPM than it is wound for and thus would stress. Given that this motor is really for lite assistance, especially on hills, can't you just pedal faster of you want to ? If you want a speed machine probably better to go for one of the other more powerfull/robust geared hub motors.
For me I want small, light, stealthy/quiet, low current draw and lite assistance. The Tongxin suits this requirement perfectly.
Looks like a minimum order of 100 from the Outrider link.
You can convince them, if you ask nicely, to buy in less than multiples of 100 if you say you want to buy some samples before committing to a larger order.
Regards
Jerry
Scottyf
1,403
-1
You can put it in whatever wheel you like but the larger the diameter at a fixed Volt rpm will mean less torque and assistance it will offer.
But it will offer a good 20mph speed. So long as you kept the amp's down it will be ok. but you will have to pedal.
amigafan2003
1,389
139
Nope - 50.4v fully charged. I'm going to try 15s of lipo on it at some point - that's 63v fully charged.
My 190rpm Tongxin in a 700cc wheel does 20mph unassisted on 44v lipo.
Scottyf
1,403
-1
Indeed but @ 44v thats will mean its rpm would be increased to 232rpm.
Which is why you get 20mph.
My bpm is would for 250rpm @ 36v (10s),
(12s)at 44v its 305rpm (24mph)
(15s)at 55v its 381rpm (30mph)
(18s)at 66v its 458rpm (35mph+)
You can run the Tongxin at those higher voltages but you will need to drop the amp's in order not to kill it.
jerrysimon
3,292
112
Cambridge, UK
amigafan2003 I would say then that you are definately pushing it to its limits :p
Regards
Jerry
Scottyf
1,403
-1
The rated values are there to allow you to understand how that motor is wound and what its operating level is.
Is the 190rpm @36v would be for 15mph in a 700c wheel.
If you keep the available power the same but change the wheel size. Say went to a 20inch wheel. The electric motor would need to be wound differently in order to achieve the same speed.
How an electric motor is wound changes the volts for speed, amps for torque trade off in a linear fashion.
Providing the magnets and stators and copper fill in volume is the same.
