Can anyone tell me why Bosch and Yamaha centre motors quote torque figers of 75-80Nm for 250 watt motors and the average 250-350W rear hub is only around 45Nm. Where is the torque measured from in centre motors? At the engine sproket or at the back wheel with the benefit of the gears. Is there more gearing in centre motors viz hub ones? I notice that range using same size batteries is not so different.
To approximate the torque at the rear wheel, let's say you have a 16T front sprocket on your Bosch CX. The internal scaling factor is 2.5, that front sprocket is the same as a 16T * 2.5 = 40T chain ring on a normal bike.
with a CD motor, you can select a different sprocket at the rear, smaller sprocket gets less torque from the motor. The maximum motor torque at the rear wheel is thus:
@ 11T = 75NM * 11T/40T = 20.6NM
@13T: 24.4NM
@15T: 28NM
@18T: 33NM (match Bafang SWXH)
@ 21T: 39NM
@24T: 45NM (match Bafang SWX02)
@28T: 52NM (match Bafang BPM)
@32T: 60NM
For example, if you ride a CX up a long and steady hill against a similar bike with a BPM motor ridden by a similarly fit pedelecer, the gradient needs to be steep enough for you to stay on 28T or higher to win.
