Hi guys,
Some more theory questions
I am struggling to find any mention of the typical motor torque provided by various e-bike hub motors. Ebikes.ca quotes the average direct drive at around 35nm, and planetary geared ones as much as 80nm. I'm not sure how that is possible considering that 250w is the maximum motor power allowed?
a 26" wheel's circumference is 2.073m
1 rps is 2.073m/s
15mph = 24.14kph = 6.70m/s
and so, 6.70/2.073 = 3.23rps = 194 rpm of the wheel for legal road speed limit!
Are you with me so far?
Lets take the average pancake motor used in the hub motors (from golden motor) 24v @ 10.8A spins at 3300 rpm.
P=VxI= 24 x 10.8 = 259.2Watts of power
T1=(60x250)/(2pi x 3300)
This basically says that the torque from the motor is equal to the power times 60 (coversion to seconds) divided by 2pi times the rotational output speed in rpm.
So T1=0.723Nm Which is fine, provided you are using a gear system...
Now, T2/T1=N1/N2
T2=N1/N2 x T1 = 3300/194 x 0.723 = 12.31Nm
Which isnt really enough to do much.
How can the other motors provide such high torque and keep it at the low power of 250w?
I read somewhere that 250w is the maximum continuous power output, but actually motors are capable of 500w+? Can someone explain this conumdrum?
1 rps is 2.073m/s
Now, T2/T1=N1/N2
