Variable contact pressure on a friction drive?
peterjd
213
52
Since there are (or have been) friction drives marketed with automatically variable contact pressure (ie between drive roller and tyre) to mitigate slip eg in the wet, I am wondering if I can fit a simpler user controlled variable pressure 'trimmer' (the basic pressure against the tyre is spring controlled) on the 'cobbled together' friction drive which I have fitted to my old Bickerton folder? I am thinking of something adapted from a cable or hydraulic brake, so that I can temporarily apply additional contact pressure to the tyre when on a hill or on wet roads to reduce slip and increase traction. Any thoughts? Incidentally the converted Bickerton is quite fun in the dry and on flat or relatively low slopes - is relatively light and still foldable so goes easily in the car boot. Peter
30,823
No reason why not Peter.
On the Zap drive, the grandfather of them all many years ago, the user dodge was to add elastic bands to the tensioning, more rain, more elastic bands!
esuark
306
208
kent
Shimano SL-TX30 left shifter might do the job. Although it says its a 3 speed shifter it just ratchets till you find the right gear, or tension in your case.
8,762
3,367
I'm certain there are better solutions but: Your cable would need a fair amount of travel, to exert enough force via a lever, which suggests to my mind either an actuated motor to exert force, as linked by @Nealh ... or a simple linear ratchet operated by a handle, of the type used on guns for silicone sealant, connected to a long cable running over pulleys to the lever. The ratchet on those sealant pumps are easily released when required.
...or of course you could use it to push instead.
8,762
Keplers device had a quite heavy sprung mechanism to force it on the tyre and devised the cable retention system to extend range mainly for longer rides , hills & headwinds for the dry seaon in Aus, he readily admitted it's wet weather down fall capability though wasn't his main concern for his use.
He did produce fittng kits to sell as quite a few ES membes like his fitting kit and the capable ones fitted there own RC motor and controller.
peterjd
213
52
Thank you for all those interesting suggestions - I particularly like the idea of a pneumatic solution. I might think about that one. More generally I think I may have some advantage with my my friction drive since the motor drive is attached by a single adjustable quick release lever to the rear forks just behind the bottom bracket. Thus the motor is slung below the bottom bracket. It effectively pivots at that point and the top of the 'front', ie other end from drive wheel, of the unit bears against the underside of the bottom bracket. So it should be relatively easy to create a lever and actuator (pneumatic, hydraulic or mechanical) to apply the additional pressure. Thanks for all the brilliant comments. It will take me time - I have had to do quite a few changes to even get this far - but I will let you know if I get anywhere with it.
Thanks Peter
PS Yes it would have been simpler to take a photo but its cold in the garage and the rain is bucketing down.
matthewslack
2,446
1,610
In those 'surely it would be really simple to...' moments when I've thought about friction drives, I always had it in my mind to hang it off the back of the seat post at a downward angle so that as well as gravity, the roller would self-servo into the tyre, thus increasing grip with increasing power level.
Under the bottom bracket is in the line of splash of the front wheel.
3,367
I very much look forward to seeing a photo of the beast.
Could you ratchet tie down to increase pressure? £1, cut off excess, release on the flat.
peterjd
213
52
For anyone interested - the current state of the friction drive Bickerton
PS I did attempt to attach the friction drive to the seat post but my home engineering skills and tools weren't up to it and it meant no pannier rack which I use for the Bosch type lawnmower battery. And yes the drive unit is in a very vulnerable postion but so far I have only used it on roads and good quality tracks.
3,367
The motor needs to be attached to pivot for the following to work, but if it were my bike and the motor slipped on wet hills, and if I was seeking a simple solution: I would increase contact pressure when needed by tightening a very large re-usable ziptie or two wrapped over the the motor and frame, or the ratcheting tie in post #10 - if needed, keeping it from sliding out of position, by securing small plastic hoops (cut off from strong plastic scissor handles perhaps, and filed a bit flat on one side for a good surface contact for Araldite to adhere to) or (nylon?) blocks to the motor and/or frame using Araldite. But I'm certain better and more sophisticated bodges can be brought into existence. (If it didn't work, Araldite softens at about 70 degrees centigrade [heat gun], becomes easier to remove).
peterjd
213
52
Thank you for that detailed suggestion. Having now had a closer look at the bike and the contents of the garage ( where I found a spare caulking/sealant gun I had forgotten about), I think I will try your suggestion in comment 5. I already have one suitable (when enlarged) hole in the top of the frame so would only need to drill a further hole to accomodate the 'actuating' rod, and fashion an appropriate lever to the drive mechanism. Thanks Peter
3,367
You're welcome. I hope to see photos of a solution worthy of The Great Egg Race: (my TV favourite programme)
17,268
All 3 teams have the same idea of a catapult. The ICL team's catapult seems best constructed having sides to guide the rings but failed to score any point.
I wonder why they did not try to have a longer ramp, that would improve the accuracy.
Reactions: guerney
