Help! Vlcd5 contoller replacement
Alanboo
10
56
Hi,
I have a tsdz2 48v 500 watt and a vlcd5 controller I was wondering what options I would have on replacing the controller with something alot smaller I don't want to modify anything just want something I could just plug in. Any suggestions please.
8,243
I assume you mean the display and want a smaller option.
One can only use one of the three standard display options depending on the connection of a 6 or 8 wire connector.
There is a SW102 minute thumb type display but one needs to buy the mid drive already flashed and configured to use it.
xh18 or vlcd6 is your only option, but you need to check the wire count and buy accordingly.
Alanboo
10
56
Hi,
thanks for the reply, i do have a 8 pin wire from the motor, the vlcd6 looks exactly what im after but i can only see it with a 6 pin connection, any ideas where i could get one ?
Reactions: Bikes4two
8,243
There lies the crux of the matter, in finding one.
TJS109
112
48
76
Glos
Hi,
There are two versions of the tsdz2 : With throttle and 8 pin connector, without throttle and 6 pin connector.
I am pretty sure the VCLD6 is only available for he non throttle 6 pin version. if your prepared to make up your own adapter cable pinouts are available on the net here is one source https://images.app.goo.gl/7QkCebBwuWJjXBvV6
Alanboo
10
56
so cut wires and splice together like on the diagram you posted
1 to 1, 2 to 4, 3 to 6, 4 to 3, 6 to 2, 8 to 5.
TJS109
112
48
76
Glos
You could do that although I would check the pinouts with another source before starting.
Alternatively you could buy terminated plugs from here
https://www.e-bike-technologies.de/index.php/en/
and splice these leads together. It is more expensive but non destructive and would not violate the guarantee on the display or controller.
As an aside you could try making this display yourself.
https://opensourceebike.github.io i
Not to be undertaken lightly I tried and failed miserably. Also It will only work with the Open source firmware
Alanboo
10
56
had a look at the plugs and wires site and cant see anything with 8 pins so thats not great, anda as far as making my own :eek::eek::eek: not a chance
Alanboo
10
56
Hi thanks for your help I think I have found a cable from aliexpress it is a 8 pin to a 6 pin and 3 pin.
8,243
Alanboo
10
56
Thanks for that link I was buying from another seller but this seller has some comments about the controller been limited to 25 kmh does any body know if there is a menu on the vlcd6 that you can override this setting like you can on the vlcd5. Thanks
8,243
