where to buy a 36v 250w geared moter wheel
footpump
713
75
75
trying to find a rear hub moter wheel to replace my bafang 8 fun 36v 250w moter wheel only 26"
but can only seem to find kits which seem to be throttle only
anyone in uk do moter wheels? as shipping from china will be costly
What type of motor wheel do you need?
Power, size, cassette/freewheel, sensored/sensorless, weight, width, speed and voltage are all important characteristics.
footpump
713
75
75
need a 36v 250watt rear hub 26" moter wheel 7 speed freewheel 135mm
revs I would think at the lower end (201) bafang 8 fun wheel is from kudos mtb
16,464
check the motor lead: 3-pin, 6-pin or 9-pin plug?
Some of the Kudos ones are sensorless. Be careful!
footpump
713
75
75
thanks woosh the original moter lead is a six pin and had bog standard unbranded 14 amp controller, led handlebar unit with 3 levels of pas.
I have a kt led 890 handlebar unit I could use, buy a new controller ? if I can source a moter wheel.
I find the 350w yosepower rear hub as fitted , uses quite a lot of battery and range is not as good as I would like
16,464
you need similar motor with 6-pin plug.
The trouble is, some motor has 1 magnet, some have 6 for the speed sensor. There is no way of knowing until you connect up the motor.
What's wrong with the old motor? may be worth repairing.
footpump
713
75
75
thanks all the moter works, what I haven't kept was the pas sensor,
also I have not got the 6 pin lead from moter to controller (think that must have been bined in error)
I have the newer kt type left hand pas sensor?
16,464
your old motor is sensorless with internal speed sensor.
you can replace the broken pedal sensor with the KT left side sensor.
