Which PAS sensor for octalink?
blu joe
17
-1
I have a trek fx 7.5 that i electrified with a 17 amp KT controller and front hub motor. I am having difficulties getting the correct pas that will fit and work, which model pas sensor do i need?
blu joe
17
-1
My bottom bracket is an octalink, maybe hollotech as i removed the crank arm before and could see right through the bottom bracket, bike is trek 7.5 fx with standard bottom bracket (pics attached in my posts)
blu joe
17
-1
Octalink cranks are wider than the standard square taper, i believe.
matthewslack
2,280
1,564
I can't offer direct experience, but when I Google pas sensor octalink I think there is enough there to find the answer, including a list of previous threads on here, and products specifically mentioning hollowtech, and known supplier names such as psppower.
8,694
Octalink or Hollowtech ?
One will need a differing type of PAS to fit each BB.
Hollowtech or the similar sram gxp type will need a BZ10C type PAS , octalink will need a PAS as indicated in #3.
The difference being the BZ10C PAS ring has the over sized inner diameter to go over the outer bearing casing.
