Happy New year folks
So I have a bought a used kit and am a little flummoxed by the wiring. And help gratefully received. I have various 36v batteries I can use to test. I'd like to do so in throttle only but the throttle is broken. I do have spares - all 36v
But this wiring is new to me
Here is the lot
Now the throttle has on/off built in and the wiring has 6 outputs in red/white/black/green/yellow and grey
But also, I'm presuming a brake cut out ? It has red and. blue wires attached as follows - red (brake) to yellow throttle , blue brake to grey and black throttle. Like this
The controller has five small outputs to match the five on the throttle. Colours are 2 x red, 2x blue and 1 x black (but the black is actually made of three wires exiting the controller
Finally the controller has a big thick wire ending in two separate points. The first is the three phase motor power (the chunky waterproof conector). The second is white and red , rather thin, and the red is soldered to strip of metal about 3 inches long. Here
Can these really be the power wires?! And if it's PAS then where is the power line ?
The motor is 250w 36v 260rpm and currently in a little brompton wheel
I have spare 36v 250w 8fun controller that is sensorless and independent throttle if need be......but I still need to get my head around this wiring
Thoughts ?
Here is the lot
Thoughts ?
