I have had to replace the bottom bracket bearings twice already, and have to regrease them at least once a month (or when it sounds like a pepper mill which ever is sooner) - Halfords have off the peg brearings that do the job. Also the bearings in the peddles need regular attention and most recently sand managed to get inside the freewheel - a soak in degreaser seemed to do the trick but it felt a bit loose afterwards.Which bits? I get bearings from Wisper but an LBS should be able to match them up, I don't think you'll get sealed bearings to retrofit.
You shouldn't need to remove the fixed cup, all the work is done from the other side.
It's a pain in the arse to clean the fixed cup from the otherside but it can be done...
