Bikernun
  1. Hersch started following Bikernun
  2. Bikernun started following Nealh
  3. Oh I see so maybe I didn't need new pas after all as I think I must of connected them the wrong way my throttle is green red and black as is the wires on controler I just presume they whent together my pas wires are g/r/b so they go to black red and white I'm presume sorry for al the questions but out of everywhere I seek help pedelecs are the ones giving correct and accurate information thanks for your help have ordered some connections and will try tomorrow andet you know cheers
  4. hi i have tried wwiring pas but still nothing I must be doing something wrong could you please tell me which wires to connect where please it would realy hell me out don't really have much knowledge of what goes where thank you
  5. Thank you neath I'll give it a try
  6. Hi all hope everyone is good I have a wiring issue I have built a 1000w 48v rear hub drive mtb the kit is a gvolt kit when I fitted everything the pas never worked so I bought a new butthe wiring is different colours I realy only want to throttle off road as I find its to much for daily commute any help would be much appreciated
  7. Thanks neath seller just got back to me and said he is refusing to refund if kit is not how he sent as I changed battery connections grrrrrrrr but I have just disconnected the motor phase wires and wheel spins freely so I'm thinking controller may have give but is only been in use for 1 week .
  8. - 48V 1000W brushless gearless hub motor hope this helps I really hope I don't need to but new wheel aswel
  9. No still hard to turn I'm sending controller kit back to seller I just want something that works so if you could recommend a 48v controller pas throttle and basic digital display price range around 100-150 thank you
  10. Also my rear wheel is very hard to turn won't freewheel
  11. Thank you so much I have taken battery out and tested direct from battery-+ and reads 54.2 volts led on battery work when I unplug from controller if this is any help thanks again for your continued support
  12. Thank you for all your help just whent of to work and my bike just suddenly dies battery is fully charged ni power whatsoever no lights on battery nor display I'm beginning to think this was a bad idea any thoughts
  13. moment ago New Add bookmark #21 Evening neath just a quick question I've contacted seller again regarding my problem and he's asking for my bms details and which side my pas sensor is I'm not an expert but this seems realy odd any advice on how to deal with this thank you for your help
  14. Evening neath just a quick question I've contacted seller again regarding my problem and he's asking for my bms details and which side my pas sensor is I'm not an expert but this seems realy odd any advice on how to deal with this thank you for your help
  15. Thanks neath your help has been much appreciated I have just got a reply from seller and he said the same as you minus checking the voltage which I have done but no volts connected white to blue and still nothing I know I sound desperate but this is me getting some freedom back after an accident and e bike is the thing helping me back in the saddle so having a throttle will really help thank you again for all your help.
  16. Thanks for your reply before I purchased the kit I asked seller if this will be plug and play and would I need to do anything else to get up and running and he said no everything will just plug in and away you gou so on that I purchased the kit which is 2 weeks ago and seller is not responding that's why I'm reaching out to to people who have knowledge of this stuff so can you tell me where the white wire has to go or do I need a new kit Thanks again for all your help
