Harrie
  1. Thanks for that. These are photos of the present one.
  2. Hi, I have a bike with BBSO2B middrive Bafang motor. At present I am using a 48V 13ah battery and getting about 30 miles range. I want to go for longer rides and I am looking at getting a 48V 20ah battery that I have been informed should give me about 50 miles. I would like help in finding a reputable company where I could buy a well made reliable battery. I live in the UK , Nort East England. I have been looking on Ebay and Amazon there are so many and averaging about £250. Much appreciate any advice and suggestions.
  3. Hi what is meant by TSBB, thanks.?
  4. This is a torque sensor.
  5. Hi thanks for the feedback. If it was a faulty Hall sensor then would you get no power from motor at all as it is ,I can ride for 8 miles the Error 42 would come on and after switching power on /off several times, I would be able to ride away. Sometimes it would come on several times during a short ride sometimes only couple of times.
  6. pictures of battery and cradle
  7. Hi, could you have used your old Carrera Crossfire battery with the kit if it still had plenty of life left in it?
  8. Sorry what do you mean by 'open'. Thanks
  9. Hi folk, need some life changing advice. I am having intermittent E42 , motor/cable, error. Halfords don't check cable for fault, they change motor and cable as one, around £450. My question is, I would like to get a kit that includes wheel with rear hub, controller, and display. I would use my present battery 36V. I am looking at something that will last and is reliable. Many thanks.
  10. Hi folk, need some life changing advice. I am having intermittent E42 , motor/cable, error. Halfords don't check cable for fault, they change motor and cable as one, around £450. My question is, I would like to get a kit that includes wheel with rear hub, controller, and display. I would use my present battery 36V. I am looking at something that will last and is reliable. Many thanks.
  11. Thanks, will try it tomorrow.
  12. Hi , I have a working Carrera Crossfire and the wheel spins backwards on that although with slight resistance but this bike with the fault does not spin at all.
  13. Thanks for reply. I have pulled the connector apart there are no pins bent and they are all shiny and making good contact. I was not sure about the back wheel not spinning freely backwards.
