Moecycle
  1. Hey! I’m moving to a country that only has 110v electricity and need to get rid of my battery welder. So, if anyone is in London and would like a free battery welder, come grab it before it goes in the bin! It works great, would be a shame to toss it. I only welded maybe 80 cells with it. It’s like new. Pick up in Canary wharf. Must be collected before March 21st. First one to come gets it. SUNKKO 737G Dual Mode Foot Spot Welder Welding Machine For 18650 / 21700 Battery AC220V Use range 1. Lithium battery and nickel battery factory, mobile power and rechargeable battery manufacturers assembly welding use. 2. Laptop repair store battery repair use. 3. Mobile phone and digital products repair store battery repair use. 4. Power tools repair store battery repair use. Specification Use voltage: AC 110v1220V910% Primary current: 2A-15A Welding current: 50A-800A Welding needle pressure: 200g-700g Single pulse welding: 0.05-0.12mm sequential nickel piece Double pulse welding: 0.12-0.15mm screen degree nickel piece Machine weight: 4.3KG Machine size: 140x245x200mm Single package weight: 5.5KG Single outer package size:215x370x310mm Welding method:pressure type Power kw:2800
  2. Just as an update, I’ve put many miles on the battery, and all I can say is WOW. These cells are nuts- the added capacity is incredible. If anyone is having trouble choosing between 18650 vs 21700, it’s a no brainer IMO. I’ll only be building 21700 from now on. These cells are great.
  3. From what I can tell that frame doesn’t have mounts for disk brakes. That’s something I always look out for in a donor frame. Not sure how powerful a motor you’re going with, but something to consider. I converted a Dawes Discovery with a YOSE 350W kit and was very pleased with the results. I personally think rear-wheel drive is the way to go. https://www.pedelecs.co.uk/forum/threads/dawes-discovery-201-yose-350w-700c-kit-samsung-25r-10s4p.41139/ Good luck!
  4. Thanks for the feedback everyone! It wasn’t a complete failure, the battery would clip when under heavier load (250W bike). It was my first battery build so there were a lot of points of failure. I tried my best to dissect it to diagnose. I found two of my welds on cell group 9 failed. Didn’t dig much after that. It was a very rough build. No cell spacers so it was under structural strain. It’s just basic foam padding to protect the battery from light impacts. https://www.ebay.co.uk/itm/261530567751?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=FeISftz6Rwi&sssrc=4429486&ssuid=zHDEdvKzSRC&var=&widget_ver=artemis&media=COPY Great idea! Do you happen to have a photo? Yeah I’m only taking 20A max. There is actually a 20A fuse in there (it’s powering a street legal 250w bike). Agreed that if I was going to draw 30A I would need to rethink my busses. this was definitely the most frustrating part of the build. I love the idea of the Y leads. Do you happen to have a photo of how you arrange these on a 4p? Yeah I’m pretty concerned about this. I had to apply way more heat than I wanted to attach those copper wires on the first and last group. If anything fails it will be this. Not doing that again… Do you have a photo of this sandwich approach? I’m thinking of a higher powered bike for my best build. Cheers everyone
  5. Hey Folks, The first battery I build finally failed, so I got to make a new one! Decided to go with 21700 cells this time. Last time I posted my battery I got a lot of great feedback on mistakes I could improve. So if you feel like giving me some feedback on this build, would be very happy to hear it. The p42a cells are from Nkon.nl BMS is a cheap Chinese unit from ebay
  6. No, Nkon took care of everything. Price listed is all you pay. molicels are doing great so far
  7. Bike is all built! we took it for a ride across London Yesterday and it was lovely. 30km ride and battery still had some life in it. Very happy with this kit, my partner said she felt she always had power available when she needed it. Likely too fast for her, but she can finally keep up with me and not have to put in any effort. Thanks for the wise words on my battery build. I agree I need to do better on the positive terminal insulation, and will buy those Rings you suggested for my next build [mention=4809]vfr400[/mention] For anyone wondering what you should budget for a build like this, here is the final Bill: Item Price (GBP) Donor bike (Ebay) 92 YOSE kit 239 BMS 11.69 Molicel 40x 137 Power switch 3.74 brake sensor 10.24 Nickel 8 foam 4 Anderson connectors 5 battery bag 17.49 Battery foam, heat tape, shrink wrap 5 disk brakes 14.94 cable wrap and holders 7.5 Brake cable 7 Fuse 2.5 kick stand 9 Panier rack 12 TOTAL 586.1
  8. I just got mine on Amazon, but the price was considerably higher (240gbp vs 190eur) shipping was quick and painless.
  9. Thanks for asking. The controller is rated at 9a cont., 18 peak. Nickel strips are 8mm x 0.15mm. I installed a 20A fuse. I had a look at this chart at by the looks of it. Even a single nickel strip would be sufficient for the continuous current, no?
  10. New battery built. Ended up going with Molicel p26a since Samsung 25R was sold out everywhere, Took the bike for a spin and it was great. Hit close to 40 km/h with the throttle only. It’s nice that the controller lets you easily set a max speed. I think I’ll keep it to 30 since my partner isn’t that confident on roads. Only complaints about this kit is the cables are too long, and the brake sensor connectors are male instead of female. I had to splice the connectors to get my magnetic sensors to fit. Last step is to bundle everything in a frame bag nicely.
  11. I bought a YOSE 350w 700c kit from Amazon, shipped from Germany last week. Ordered on Sunday, arrived Tuesday Morning (somehow!). https://www.amazon.co.uk/YOSE-POWER-Conversion-Freewheel-Brushless/dp/B07MW3CTV3/ref=mp_s_a_1_1?dchild=1&keywords=yose+power+700c&qid=1621850539&sr=8-1
  12. Placed an order for 40 Molicel from Nkon on May 15th, delivered today May 21 by DPD they took care of customs/vat paperwork. Great price overall.
  13. Hi Folks, First off, thanks to everyone who provided feedback! Build is going pretty well so far. Rear wheel went on like a charm. Disk brake as well. If I'm lucky I'll be able to wrap up the electronics and brake cables this weekend.
  14. Thanks! I’ve ordered the kit. I also ordered some magnetic brake sensors (seemed they will do the trick). For the disk brake, I’ll go with a mechanical disk caliper. I’m pretty sure it will fit on the frame (photo attached). I’ll sort this part out after the kit arrives.
