- Kudos Sonata LCD Not Showing MPH
Thank you both for your replies. This bike has no external sensor or magnet....i would guess the signal must come from the motor to the speed controller...i will take a look for that white wire....also could it be caused by a wire going into the king lcd display ??? also ive noticed when i use the thro ttle on this bike it is very low speed and very slow...so is this ment just for pulling off then to use pedal assist ???
daverave started following Carrera Vulcan E Bike E42 Fault , Kudos Sonata LCD Not Showing MPH , Kudos sonata and 7 others
Kudos Sonata
anyone got a photo of the kudos sonata battery
- Kudos sonata
- Kudos sonata
- Kudos sonata
SUNTOUR HESC LED DISPLAY VOLTAGE ????
All i remember is that the mosfet was shorted gate to drain...and i found no wires touching.
When i first looked at the display the power switching transistor was short circuit...so i replaced it and new transistor got burning hot !!! i cant believe the supply voltage to this display would be at the 36V battery voltage !!! it surely would be regulated down to a much lower voltage.......without a schematic it makes fault finding that much harder !!!! how can i give you info that i do not have as i know very little history of the item !!! maybe it received a reverse polarity ???
SUNTOUR MOTOR FREE HUB PROBLEM
ok thanks
The chips have no markings on them as they were covered in resin and getting the resin off has taken off the code numbers of the chips.
The circuit is drawing an excessive amount of current and two of the chips are showing shorts across several of the pins !!! if not over voltage then it must be reverse polarity.
Thanks for that...ive had to order the tool from ebay and comes from China .....to remove the sleeve nut is it clockwise ???
daverave
Joined
Last visited
