D8ve
  1. johneb started following D8ve
  2. ebrom started following D8ve
  3. I do hope they have automatics, browning high powers, revolvers are so last century old chap.
  4. A MOSFET is like a carburettor, it allows power to energy into the engine. More is better if you need high power. 6 is about the minimum and 12 is common but not nessiasry for a 350 watt bike.
  5. 34 miles 1'55" and 1300' climbing. Come to the fast side my friends.
  6. It's the brexit troll who has never biked. I could put up with everyone else.
  7. thanks to D8veh,Flecc and others for advice education and support. I have two velomobile snow and get 18 mph averages without electric assist. So I will not need to frequent these pages. It's been interesting and enjoyable, only one person on my ignore list. Trex is missed too for his trustworthy advice. So long and see you on the road.
  8. She had it coming
  9. The Tory policy is to force scum onto bike as could never afford a proper 4*4
  10. Test ride every bike with the power off. It shows two things, what it would be like with falt battery, as above And just how good a bike it is, if it's a dog then the battery has to fight that before it gets to help you, so short range etc.
  11. 21 gears is a flash advert spec for cheap gears. Ebikes can make do with 7 gears and if you only need 15 mph then 3 speed is plenty.
  12. Disk brakes are a no brainer nowadays. Great stopping power in the wet and hydraulics don't need adjustment for thousands of miles.
  13. The wattage is controller dependant. The basic idea is voltage it runs at times max rated current equals max power. The second is manufacturers also have a rated power. For a 250watt motor or legal classification they often run at max of 6-800 watts. Motors rated at 500 watts tend to be limited to 500 watts, if they could do more they would be called 1000 watt motors etc
  14. Don't bother I have suggested jobs but he's making too much as he is.
  15. No bikey mcbikeface was trashed by a van. I was invisible in a 3 meter banana. This is the replacement I have bought. Pending insurance etc.
  16. To avoid Lycra and stay dry, one of these with assist and you will do more than 20 on the flat too.
