Cyclamatic Power Plus Intermittent Motor Cutting Out
Hi Personally I detest those OE connector blocks! The neatest & most reliable solution IMO is to cut all the wires, then solder them back together according to colour / thickness, with some appropriate shrink tube for each wire, and a larger diameter over the whole lot once satisfied that all the wiring is present & correct. Old Cyclamatics never die, they just get modded... They have a good, reliable motor ( maybe not the gruntiest, I grant you ), & age shouldn't be an issue if you keep on top of the basics. Mark
Hi I'm Rob, I live near Stafford in England but I also live part of the year in Lanzarote
Hi Rob, Glad it's all sorted once and for all now That contact at Urban Mover could come in handy as I have a few UM10 controllers with LCD display , that came without the speed sensors. I have a "universal" speed sensor to try out, but may need some pointers! (Unless anyone here knows how to do it...) All the best, Mark
Discontinued Battery
Is it one of these? http://www.ebay.co.uk/itm/282485052764 Regards Mark
Help with chain
Or, as you have already ordered a chain, order another one the same & make one of the correct length out of the two. Mark
lots of information
Hi Lee, Welcome to the forum Regards Mark
Help with chain
Hi, The 18/21/24 means the number of gears when matched to a triple chainset at the front. Pretty much any chain will be up to the job. This is what I just ordered for a Coyote Connect, and don't foresee any problems with it: http://www.ebay.co.uk/itm/231880818946 Hope this helps. Regards Mark
Hi Rob, What reading,if any, are you getting from the output terminals? It's possible that there is one or more weak cells causing the bms not to allow charging, or the bms isn't working for some other reason. If you dismantle the case and take readings from the bms where the connector attaches the sense wires to it, that should give you an idea of the health of the cells, or where the problem may be. There's lots on the forum on the subject (including my own recent questions ). Always happy to help if I can:) Regards, Mark
Hi Rob, If you haven't sorted a new charger plug yet, how about this? http://www.ebay.co.uk/itm/162440632513 Regards Mark
Need help ebike not working
Hi Louise, I live in Hull & am happy to help in any way I can. PM sent. Regards, Mark
Pro Rider E Tourer Bike.
Hi. Can't help you with redistricting your bike, but the 5 wires to the throttle thing is possibly because 2 are for battery state LEDs or an on/off switch? Regards, Mark
Can somebody please help?
Hi Danielle, I live in Hull & am willing to help in any way I can. PM sent. Regards Mark
Another battery problem
Hi D8veh, Apologies for taking my time to get back to you, hardly had a chance to get on with it. Unplugging it didn't have any effect, but in the process of doing so I was getting flashes of c 42v. It seemed to be when the BMS had some pressure on it or was being slightly flexed but couldn't get it to sustain the reading. To cut a long story short I swapped the BMS for another one, and all's good Did another battery with the same symptoms too. Thanks for your help, it certainly got me on the right track. Kind regards, Mark
Here is where the measurements were taken from - And a pic of the BMS. Hope they're clear enough. Would I be able to put 36v from another battery into the BMS to switch it on? Mark
Hi again, The voltages I'm getting are 4.2,,8.4,,12.6,,16.7,,21.1,,25.3,,29.5,,33.7,,38,,42.2. So can't see where the problem lies.... Mark
Thanks D8veh, will do. Mark
mw1
Joined
Last visited
