September 16, 20169 yr Hi, this is my first post here, I am fitting a BBS01 kit to a 1995 Dawes hybrid with a 42t lekkie chain ring, but in the process I lose the ability to mount the kit-supplied plastic chain guard and am thinking about a replacement. I assume I can't use a bottom bracket mounted chain guard because of the motor, I found through Googling that Velo Orange sell a french style chainguard that attaches to the frame with band clamps and is open at the back so should accept any width chain ring, but would an enclosed Hebie Chainglider work given the 9mm wide chain wheel tooth offset on the lekkie chain ring? The Hebie specs indicate max. chain wheel width 3 mm and max. chain width 9 mm. I have sent an email to Hebie support but wondered what the forum members use, thanks for your thoughts. Edited September 16, 20169 yr by Dewey
September 17, 20169 yr Damn that Velo Orange is nice. I like shiny things. Would buy it but I have 48t ring and changer. Nice find Dewey, sorry I can'y help.
September 17, 20169 yr sks do one designed for a triple chainset that goes behind the BB but has offset to clear a triple with 48 tooth outer. was tempted to give that a shot on my bbs02 when it arrives. Found it on rose bikes.
September 17, 20169 yr https://www.rosebikes.com/article/xtreme-triple-chain-case/aid:161645 sorry its "xtreme" which is rose own brand i think. Still looks fair dinkum
September 17, 20169 yr No idea if the chainglider would fit, but they are a top piece of kit. Really good for my commute on country track and road. John
September 17, 20169 yr https://www.rosebikes.com/article/xtreme-triple-chain-case/aid:161645 sorry its "xtreme" which is rose own brand i think. Still looks fair dinkum That would do the job except for having the pas sensor on that side, but it ain't as tasty as that Velo Orange one. Wonder if I could make it fit?
September 17, 20169 yr My bbs02 hasnt arrived yet but what stops you putting this between pas sensor and the bb shell ?
September 17, 20169 yr Author I've put my PAS sensor on the left non-drive side, I just assumed a Bottom Bracket mount would not work on the drive side hence my looking at frame mount & chain case options.
September 19, 20169 yr Author Hebie customer services confirmed the Lekkie chain ring isn’t compatible with the chainglider chain case, so I'm going to try a Kaul Unidisc. Edited September 19, 20169 yr by Dewey
September 22, 20169 yr Author So the Kaul Unidisc does not work, and isn't a universal fit. It screws into where the dustcover screws in. Only works with all in one cranksets, or bent crank arms. The wide Bafang crank arm pushes the disc 2 inches outboard the chain ring. This would interfere with pedaling.
September 23, 20169 yr Author A New Zealand Bafang ebike kit dealer is selling a chain guard bracket that bolts on the back of the motor drive disk. I am unsure what size screws bolt into those holes on the back but this looks promising as a mount. Edited September 23, 20169 yr by Dewey
September 26, 20169 yr Author Techbikes say the bracket bolts onto the back of the BBS motor disk with M3 screws.
January 29, 20179 yr Author So I had time at the weekend to work on this. In the end I bought an SKS chain board from Amazon and chain guard hardware from Velo Orange. Left off the bottom bracket mount and instead drilled two holes in the plastic guard to mount it on the down tube with the VO brackets.
