April 4, 20179 yr finding hills and gear changing on a push bike difficult as I get older. I'm 5ft 5 ins and weigh 9 stone. Looking for a smallish electric bike for leisure use and to take away with the campervan. I don't want small wheels and have a bike rack that is suitable for an electric bike with battery removed. Any advice appreciated. Would hub gears be an advantage? Limited options to try out a range of bikes in my area
April 4, 20179 yr Hello Peggy, I would recommend you to look at the Woosh Petite. It is smaller than the average step through, gentle at the start and has a throttle in case you feel too tired to pedal. It has front suspension, easy on your wrists and back. You can also choose the battery capacity to suit the range you like to have, 10AH for about 30 miles, 13AH for 40 miles or 15AH for 50 miles. Price from £829 including delivery. http://wooshbikes.co.uk/?petite
April 4, 20179 yr I'd like to see the bike that is 17k must be made of gold or all components are titanium. Edited April 4, 20179 yr by Nealh
April 4, 20179 yr Hi Peggy, I wouldn't discount 20" wheels unless you have tried a bike with them and really don't like them. I have tried the Winora Radius and the Orbea Katu, both of which felt a good ride to me as a 'tour' bike. I have ordered the Katu e-20 in white which should arrive in the next couple of weeks. The Bosch powered e-30 is close to your budget; http://www.tredz.co.uk/.Orbea-Katu-E-30-LR-2017-Electric-Bike_95519.htm?sku=337479&utm_source=google&utm_medium=cpc&utm_campaign=google_shopping&gclid=CIKXu-TnitMCFSgz0wodilgHbw though it doesn't have the hub gears that the e-20 has. Like you, mine is to take away in the Renault Master based campervan where it will sit x ways inside the rear doors. I'm looking forward to having hub gears - derailleurs are a pain to me! Cheers Kendalian
April 4, 20179 yr Author Thanks Woosh but I think the petite is slightly too small. I have considered the Santana 2 but would like to test before I buy and Southend is too far for me.
April 4, 20179 yr Author Hi Peggy, I wouldn't discount 20" wheels unless you have tried a bike with them and really don't like them. I have tried the Winora Radius and the Orbea Katu, both of which felt a good ride to me as a 'tour' bike. I have ordered the Katu e-20 in white which should arrive in the next couple of weeks. The Bosch powered e-30 is close to your budget; http://www.tredz.co.uk/.Orbea-Katu-E-30-LR-2017-Electric-Bike_95519.htm?sku=337479&utm_source=google&utm_medium=cpc&utm_campaign=google_shopping&gclid=CIKXu-TnitMCFSgz0wodilgHbw though it doesn't have the hub gears that the e-20 has. Like you, mine is to take away in the Renault Master based campervan where it will sit x ways inside the rear doors. I'm looking forward to having hub gears - derailleurs are a pain to me! Cheers Kendalian Thanks for the advice. I have tried 20" wheels and really didn't like them. My ideal is for a 44-46cm frame and 26" wheels. Edited April 4, 20179 yr by Peggy
April 4, 20179 yr Thanks Woosh but I think the petite is slightly too small. I have considered the Santana 2 but would like to test before I buy and Southend is too far for me. Thank you Peggy for looking. The Santana2's motor is too powerful for your 9 stone. It is made for people who weigh between 12 stone and 16 stone. Even on low assist, it will assist a bit too much for your 9 stone. There is also the length of the bike. The Petite is 172cm in length, the Santana2 is 189cm in length. The longer the bike, the more stable the bike is but length also makes the bike less agile. It follows that slim people are better off with shorter bikes and vice versa. I will add the info to the web page later to make it clear.
April 4, 20179 yr Author I'd like to see the bikes that is 17k must be made of gold or all components are titanium. Whoops - that's my autocorrect. I mean under £1,700!
April 4, 20179 yr Whoops - that's my autocorrect. I mean under £1,700! That's a shame Peggy! Have you considered a Wisper 705Torque, it's a well built, silent, powerful and sophisticated bike that falls bang into your range? If you let me know what's you are based, I would be happy to recommend a local Wisper Dealer where you will be able to test ride a bike. All the best, David Edited April 4, 20179 yr by Wisper Bikes
April 4, 20179 yr Author That's a shame Peggy! Have you considered a Wisper 705Torque, it's a well built, silent, powerful and sophisticated bike that falls bang into your range? If you let me know what's you are based, I would be happy to recommend a local Wisper Dealer where you will be able to test ride a bike. All the best, David [ATTACH=full]18529[/ATTACH]
April 4, 20179 yr Author That looks a possibility although the frame size is slightly larger than my ideal. I'd like to test one of you are able to find a local dealer for me. I live in Norfolk
April 4, 20179 yr Hi Peggy We have a number of stockists throughout Norfolk, and I think you'd like the feel of our Classic range. Take a look at our electric bike stockists map to find the most convenient for you.
April 4, 20179 yr Author Hi Peggy We have a number of stockists throughout Norfolk, and I think you'd like the feel of our Classic range. Take a look at our electric bike stockists map to find the most convenient for you.
April 4, 20179 yr Hi Peggy, if you are near Croma, Pop in and see David Wood from Electrifying Cycles, he's one of the most knowledgable ebike dealers I know. He will have a lot of bikes and brands for you to try. All the best, David
April 4, 20179 yr Author Hi Peggy, if you are near Croma, Pop in and see David Wood from Electrifying Cycles, he's one of the most knowledgable ebike dealers I know. He will have a lot of bikes and brands for you to try. All the best, David Thank you I will.
April 4, 20179 yr Whoops - that's my autocorrect. I mean under £1,700! ... I want an autocorrect like that installed in my bank account!
