March 21, 20188 yr Hi there just bought a fat bike, and was wondering is it possible to put different wheels on such as semi fat as obviously the hubs on a fat bike are rather wide. Thanks
March 21, 20188 yr You can build any rim onto any hub as long as you have the same number of spoke holes in each. Obviously, you have to make sure that you have enough frame clearance if you go to a larger diameter or wider tyre.
March 22, 20188 yr BUILD that might be beyond me Thanks for the info You could always have a bike shop build one for you.
March 22, 20188 yr Author Ok thanks did think that might need to ask, Any ideas how much they would charge?
March 22, 20188 yr Ok thanks did think that might need to ask, Any ideas how much they would charge? It depends whether they saw you coming or whether they saw you park your expensive vehicle outside the shop.
