Taxi changes direction at traffic lights
works with windows
It works with Windows at the moment :D I use assignable controls for various DAW functions using MIDI keyboards, which are far more likely to work with Windows in several years time, particularly as I don't currently intend to go higher than version 7.
https://www.grc.com/never10.htm
  • Replies 158
  • Views 19.2k
try using cv and gate with midi and sync it all up with world clock bnc cables so it can go to the 16 track hard drive recorder as a mix then dump it to dat fkn mission lol.
all the outboard gear was linked via the connectors to bantam patch bays on the right of the desk and had a crt monitor and basic computer and psu fkn huge lol.
https://www.youtube.com/watch?v=OwQwHW_oq-k
Edited by soundwave
fkn mission lol.
I had an Atari STfm 520 - Carrier Command the days of early 3D - I did have a music program but the only track I had was prodigy out of space, I never did get into music on a deep understanding level.
Although after getting a dot-matrix printer to work with the Atari I caught the IT bug. The printer would sit there all day switched on but never worked & I would try the print function and switch it off when it didn't work, but one day I left it on and after about an hour it printed syntax and then the picture I was testing with, I had to do this process every time I wanted to print after it was switched off but once it had warmed up it printed anything in all it's dot matrix glory.
a lot of cabs will go into the right lane at a light (which is empty because there are parked cars just ahead of the light)
Should you not merge in turn instead of racing? Using all the road space helps ease congestion.
Anyhow
Do what's fun. I do. I stop when it stops being fun.
I am enjoying editing as it goes, a lot to keep track of, nearly at the final edit, trying to shorten it and keep it funny is proving hard, tbf I am going to sound like a bit of mad man.
Why fuss so much? I could have spent ages cutting around Ray Liotta's head and outputting each frame as PNGs with transparency, so that his head floated next to the car being forced onto the pavement, also could have mucked about endlessly with timing, more frames, more images, more text... but really, if it's not work you're going to get paid for, why bother? Just enjoy it, and if it makes you and others laugh or smile (at the very least), it'd be worth it.
Edited by guerney
It seems to be one of the ways they amuse themselves... It's also a way I amuse myself. Let the clutch out a bit, roll up, watch cabby roll up, clutch back in, roll back and watch cabby all confused. If you repeat it 3 or 4 times, you can have them halfway into the intersection by the time the light actually changes!
[links removed by admin]
Dude are you a spambot? You've copy/pasted your own post and linked to something or other twice in your signature. Say no I dareya!
Edited by HelenJ
are you a spambot?
You can report a post below the post there is a "report" button...
:p
I think I have finished my video...
Editors/Directors notes -
Apologies for sound, the music doesn't go all through the video, just intro, a little in the middle and some at the end.
The voice audio in the middle, was a choice, either louder or less noise, I choose the later.
