May 14, 20232 yr Anyone know a way of increasing the assisted speed limit on a Tailwind. Only after a couple of extra Mph just to trim my commute time.
May 15, 20232 yr Author Add more tailwind... I can box off my commute in 30mins on my gravel bike but need a shower when I get in. Thats the reason why I got a pedelec, no effort, no stress, save money !
May 15, 20232 yr Anyone know a way of increasing the assisted speed limit on a Tailwind. Only after a couple of extra Mph just to trim my commute time. There's no legal way, 15.5 mph is the assist limit, with the statutory 10% tolerance allowing 17 mph, but Wisper only make legally compliant pedelecs. A higher assist speed would mean a modified or different controller and/or a higher voltage battery, but with a hub motor pedelec like yours with everything integrated, such changes would be both difficult and expensive. A better course if higher speed was wanted on an assisted bicycle is to have bought a CE approved S class high speed pedelec and register it. A bit more bureaucracy necessary, but assist speeds up to 28 mph then legal, slashing your commute time. .
May 15, 20232 yr Author There's no legal way, 15.5 mph is the assist limit, with the statutory 10% tolerance allowing 17 mph, but Wisper only make legally compliant pedelecs. A higher assist speed would mean a modified or different controller and/or a higher voltage battery, but with a hub motor pedelec like yours with everything integrated, such changes would be both difficult and expensive. A better course if higher speed was wanted on an assisted bicycle is to have bought a CE approved S class high speed pedelec and register it. A bit more bureaucracy necessary, but assist speeds up to 28 mph then legal, slashing your commute time. . Thanks Flecc, I appreciate your time. I understand that I could have sourced a faster alternative but I had to buy the bike through C2W, it was the only way the wife would sanction it. So I ened up going for an 'off the shelf' bike.
May 15, 20232 yr Author Thanks Flecc, I appreciate your time. I understand that I could have sourced a faster alternative but I had to buy the bike through C2W, it was the only way the wife would sanction it. So I ened up going for an 'off the shelf' bike. I didn't know there There's no legal way, 15.5 mph is the assist limit, with the statutory 10% tolerance allowing 17 mph, but Wisper only make legally compliant pedelecs. A higher assist speed would mean a modified or different controller and/or a higher voltage battery, but with a hub motor pedelec like yours with everything integrated, such changes would be both difficult and expensive. A better course if higher speed was wanted on an assisted bicycle is to have bought a CE approved S class high speed pedelec and register it. A bit more bureaucracy necessary, but assist speeds up to 28 mph then legal, slashing your commute time. . I didn't know thee was a statutory 10% tolerance... even that would do me, I'm not after anything above 20mph really
May 15, 20232 yr Thanks Flecc, I appreciate your time. I understand that I could have sourced a faster alternative but I had to buy the bike through C2W, it was the only way the wife would sanction it. So I ened up going for an 'off the shelf' bike. Understood. Perhaps content yourself with the fact that our original EAPC assist limit fifty years ago was 12 mph, so at 15.5 mph now you're riding 29% faster. Progress! .
May 15, 20232 yr Author Understood. Perhaps content yourself with the fact that our original EAPC assist limit fifty years ago was 12 mph, so at 15.5 mph now you're riding 29% faster. Progress! . True
May 15, 20232 yr I didn't know thee was a statutory 10% tolerance... even that would do me, I'm not after anything above 20mph really That's the general 10% tolerance for all speed limits, and the DfT have confirmed it alo applies to pedelec assist speed. It's actually a design tolerance to allow for small errors. There's no way you can apply it though if the manufacturer hasn't designed it in. I only know of one who did, Kalkhoff on some of their later pedelecs which assisted to 27.5 kph / 17 mph. A pity the motor in those were so unreliable though. .
May 15, 20232 yr Author I'm enjoying the ride anyway, so I think I'll get over it . Save the speed for the gravel bike !!!
May 15, 20232 yr Someone accidentally changed the wheel size on their Wisper https://www.pedelecs.co.uk/forum/threads/accidentally-de-restricted-my-bike.38118/
May 15, 20232 yr You should have asked the dealer for the secret code before you handed over your money. You have no bargaining power now. It's surprising what some dealers will do when their £400 profit is hanging on it.
May 16, 20232 yr Author Someone accidentally changed the wheel size on their Wisper https://www.pedelecs.co.uk/forum/threads/accidentally-de-restricted-my-bike.38118/ I had seen this post a while back but unfortunately it doesn't work with mine.
May 16, 20232 yr Author You should have asked the dealer for the secret code before you handed over your money. You have no bargaining power now. It's surprising what some dealers will do when their £400 profit is hanging on it. Didn't even occur to me at the time. I stumbled upon the post about changing wheel size after bought the bike
May 16, 20232 yr You can fit larger tyres, this will increase the circumference and slightly increase speed.
May 16, 20232 yr Who comes up with these names ?. Wisper 'Tailwind' There should be a competition/poll see who can come up with the best most fitting name than may(or may not) make it to the market. Not the features or components, just the name.
May 16, 20232 yr Who comes up with these names ?. Wisper 'Tailwind' There should be a competition/poll see who can come up with the best most fitting name than may(or may not) make it to the market. Not the features or components, just the name. Hi Andy, it normally takes a lot of thought. This time I was on a flight and heard the captain say we have a "Tailwind" so we expect to be in London 30 minutes earlier than expected. But didn't someone once say... “What's in a name? That which we call a rose by any other name would smell as sweet.” All the best, David Edited May 16, 20232 yr by Wisper Bikes
May 16, 20232 yr Hi Andy, it normally takes a lot of thought. This time I was on a flight and captain say we have a "Tailwind" so we expect to be in London 30 minutes earlier than expected. Heaven knows what prompted Germany's Kalkhoff to name their first pedelec. Agattu An island in Alaska, part of the Near Islands in the western end of the Aleutian Islands. .
May 16, 20232 yr Heaven knows what prompted Germany's Kalkhoff to name their first pedelec. Agattu An island in Alaska, part of the Near Islands in the western end of the Aleutian Islands. . I thought it was from Agattu doo doo, push pineapple, shake the tree! All the best, David
May 16, 20232 yr I thought it was from Agattu doo doo, push pineapple, shake the tree! All the best, David Apparently not, according to 50C and Derby Cycles gmbh, solemnly giving the location of that island. Wouldn't grow many pineapples at that latitude! Truth is they may not even remember, since they had made normal unassisted Agattu and Pro-Connect bicycles for years before they produced the modified frame versions to use Panasonic mid motors for their first pedelecs. .
May 16, 20232 yr There should be a competition/poll see who can come up with the best most fitting name than may(or may not) make it to the market. The Boris. An eBike that breaks all the rules .........................
May 16, 20232 yr The Boris. An eBike that breaks all the rules ......................... We’ve had plenty of Boris bikes in London
May 17, 20232 yr Heaven knows what prompted Germany's Kalkhoff to name their first pedelec. Agattu An island in Alaska, part of the Near Islands in the western end of the Aleutian Islands. . Agattu getta more exercise?
