October 13, 20232 yr There is no provision for attaching brake sensors. If you convert bikes professionally, this kit is well worth considering because of its simplicity.
October 13, 20232 yr I assume you bought already. However, the Eleglide T1 step thru from geekbuying is certainly worth a gamble. Uk stock, fits your price range. Plus, currently select the multi buy for a free second battery. (Buy Together & Save) Edited October 13, 20232 yr by alanbonne
November 2, 20232 yr [mention=14891]billyboya[/mention] bought one of those Soodoos several months ago. IIRC he bypassed Amazon for a cheaper deal directly with the distributor. After some initial problems with display configuration, he hasn't been heard from since, so he must be getting on ok with it. Hi yes the bike is working a treat, yes I went straight to soodoo web site and got bike cheaper. I need to adjust the brakes a bit now, but apart from that all is running fine. I use it nearly every day. apart from when its bad weather But I looked on soodoo web site and it seems now on there its much more expensive @ £649.99 GBP But on Amazon its much cheaper at £549.99 https://soodoo.co.uk/products/ebike-02wo
