2379 spare key
Hi just wondering where is can get a spare key, (i only have 1)huiye docs 2379 .its for the battery lock on a wisper 705.
Hi if you’ve lost your keys you will need a replacement lock barrel and keys. They are available on our website. We can talk you through how to bypass the lock so you can remove the battery. All the best, David
9 times out of ten, you can open those logs with jiggler keys from Amazon. Watch a couple of Youtube videos on how to use them.
Its probably cheaper and less time consuming to get a replacement lock and fit ( 1 x evening and 1 x shopping order) than faf about trying to get an extra key.
You could try a local key cutter timpsons close to me are helpful and matched a slightly thicker blank to my post box lock key.
