May 1May 1 Hi guys, I'm re-assembling a Suntour HESC700c rear hub motor, the feather key that locks the planetary clutch onto the shaft is missing.I don't have a set of callipers to hand to measure it so was wondering if I could find a spec sheet somewhere with the key size detailed?Thanks
May 1May 1 2 hours ago, Squallog said:Hi guys, I'm re-assembling a Suntour HESC700c rear hub motor, the feather key that locks the planetary clutch onto the shaft is missing.I don't have a set of callipers to hand to measure it so was wondering if I could find a spec sheet somewhere with the key size detailed?ThanksYou can measure with a tape measure or ruler. They're always a standard size, so you only need to measure to the nearest mm. You get the length from the shaft and the width from either the shaft or the other bit.https://www.aliexpress.com/item/1005009201906687.htmIf you lost it, have a look at anywhere that's magnetic on the motor. That's where they usually end up. Edited May 1May 1 by D8veh
May 2May 2 Hi It’s me from e bay good to see u on here Do you have a photo of what need .The member who was going to start fixing motors but gave it up through illness found some bits on Ali Express he sent me back a box of disassembled motors but I am not sure what you need so I may have it .You can have one if I have it .CheersBaz
Saturday at 08:304 days You can buy a digital vernier caliper quite cheaply, lidle have them sometimes
