Press fit bb and mid drive onversion
Bjl
Oct 19, 2019
I have a nice Cube gravel bike that I've put flat bars on, it would make a great donor bike for a mid drive conversion. The only problem I'm not sure about is that it has a press fit bb . Works it be possible to put a bsa threaded insert into the bb to accomadate a bafang or tongsheng motor . Cables under bb may possibly need rerouting too .q55285
Bikes4two
896
398
Havant
I've no idea as to the sizing of the bottom bracket system that you have, but if there's room for a BSA type insert then Ceeway ( https://www.ceeway.com/ ) might well have something for you.
Years ago the BB on my carbon frame Trek Madone gave up the ghost and no dealer would consider a repair. I got a steel insert from Ceeway and with some monor tinkering and a fair bit of industrial grade epoxy, the BB insert was fitted - that was some 10 years ago and a few thousand miles on and there's never been a problem.
Peter.Bridge
671
303
Reactions: Bjl
2,078
You'll have to fabricate something to stop the motor rotating around the BB when you have a PF BB or adapters. The TSDZ02 has such a bracket that fits some bikes, but not others. It looks like it won't fit yours, but your photo isn't sufficient to be sure.
Reactions: Bjl
