1000W 48V Hub Conversion Kit
aaannndddyyy
304
9
63
Norwich Norfolk
I have just finished building my latest kit which I bought off EBay, it is the 1000W 48V Electric Bike Hub Conversion Kit 1000 W 48 V Electric Bicycle Bike Hub Conversion Kit on eBay (end time 23-Sep-10 02:39:17 BST)
Here are some before and after pictures.
Heimzmann 24v
200w
176/min
Ezze Sprint 36v battery
8A
Statistic Speed Distance Duration
Fastest 50m 27.5 mph 135 m 0:00:11 49-50
Fastest 100m 27.5 mph 135 m 0:00:11 49-50
Fastest 250m 26.4 mph 259 m 0:00:22 48-50
Fastest 500m 15.0 mph 584 m 0:01:27 43-50
Fastest 1000m 13.6 mph 1.07 km 0:02:56 43-58
The kit took 2 weeks to arrive and was very easy to install, it has taken me just 3 days from start to finish to completely strip and rebuild this bike.
Item details: Specification for 48V1000W front & rear motor
I am using a Ping 48v 12a V2 battery in a back pack
and have just arrived back from my first test ride here are some stats
Fastest 50m 31.4 mph 154 m 0:00:11 70-71
Fastest 100m 31.4 mph 154 m 0:00:11 70-71
Fastest 250m 31.2 mph 391 m 0:00:28 70-72
Fastest 500m 30.4 mph 625 m 0:00:46 70-73
Fastest 1000m 29.8 mph 1.09 km 0:01:22 70-75
Ground Length:
10.1 km
Average:
17.8 mph
Max Ground Speed:
31.4 mph
As you can see this kits will do what it says on the box.
(All testing and riding of this bike was and will be done on PRIVATE land)
30,823
Nice job Andy, pity the battery isn't on the bike though.
This is certainly the best way to use these direct drive motors, on high voltages for speed when they are at their best.
Don't go overtaking any police cars on those private roads though. ;)
aaannndddyyy
304
9
63
Norwich Norfolk
I have got used to the battery on my back (balanced weight, light bike) with my DH TWD (downhill, two wheel drive) ebike, it makes the ebikes feel like normal bikes, i tried the battery on the rack it just doesn’t feel right.
30,823
On the rack I agree Andy, that's a large heavy battery to have high at one end of the bike. I was thinking of an in-frame casing maybe, though it's true what you say about the bike feel. Our bodies and anything we carry are really sprung weight, remote from the bike.
my.motion
115
Hi,
How much was the battery and charger for this kit? can't find the batt. on ebay.
Regards
Motion
Barnowl
954
I couldn't tell the difference, even with a magnifying glass. What's he done to that then eh?. Then I scrolled down and found the "after" piccies. :eek:
Extremely impressive looking upgrade.:cool: :cool:
aaannndddyyy
304
9
63
Norwich Norfolk
Thanks. Oh my!! these batteries are quite expensive, this makes the cost of everything close to £900.
The kit cost 207pounds, and the Ping battery cost 300 pounds 10 months ago, total cost for this set up 500 pounds.
No import duty
And no tax
Plus around 100 pound for the bike.
Total cost all in up and riding around 600 pounds.
I have updated the pictures in the first post needed to upgrade the brakes plus half a dozen other little changes to improve the overall running of the bike.
Just finished a distance test
Allmost flat no hills to speak of (Norfolk)
Ping 48v 12a v2 battery
Track Length:
35.1
35 kilometers = 21.7479917 miles
Before BMS (battery management system) cut in and cut off the electricity supply.
Outward leg against the wind.
Fastest 50m 31.4 mph 154 m 0:00:11 84-85
Fastest 100m 31.4 mph 154 m 0:00:11 84-85
Fastest 250m 29.7 mph 292 m 0:00:22 194-196
Fastest 500m 29.5 mph 580 m 0:00:44 192-196
Fastest 1000m 29.2 mph 1.00 km 0:01:17 191-198
Homeward leg with the wind
Fastest 50m 33.4 mph 164 m 0:00:11 41-42
Fastest 100m 33.4 mph 164 m 0:00:11 41-42
Fastest 250m 33.1 mph 326 m 0:00:22 41-43
Fastest 500m 31.8 mph 625 m 0:00:44 40-44
Fastest 1000m 31.0 mph 1.07 km 0:01:17 37-44
Madness
15
Norwich NR1
Ill keep an eye out for you around norwich aaannndddyyy. I was looking at one of the 1kw kits myself but got a 250w.
my.motion
115
Hi Andy, Does the 26 inch front tyre motor fit on 700c type bike? what make is the bike you used. Most of the bike I look at with panniers town/commuter type have 700c tyres :( I am looking to buy a kit from this guys and I am looking for a bike with panniers etc at reasonable price 100-150 quid. thnx
aaannndddyyy
304
9
63
Norwich Norfolk
The bike is an old Raleigh Sprinter with standard 700cc wheels the 28”rear wheel went straight into the frame without any modification.
I have had the bike running for a while now without any major problems the motor and controller work fine together, the rear sprocket had to be replaced strait away as it was CRAP also the throttle was cheap and very jumpy and needed replacing, plus the wiring from the battery to the controller wasn’t thick enough gage and was getting to warm used 10 awg which is fine.
aaannndddyyy
304
9
63
Norwich Norfolk
thanks for the reply. how did you waterproof the controller/battery?
For the battery I found a plastic CD storage box that was slightly bigger than the battery and bms padded and fitted the battery into than, then put the box into an old camera bag then put that into a back pack.
I have been off the bikes a few times now the battery has survived a couple of heavy hits on and off road.
As for the controller I took the side covers off and ran a bead of silicon sealant around the rubber seals, then got a small box from maplins, drilled a hole in either side and ran the wires and connector into that (See pic of bike) Small Narrow Box : Plastic Enclosures : Maplin I used pvc tape to seal up each end, so far have had no problems with wet weather.
aaannndddyyy
304
9
63
Norwich Norfolk
I know this is an old post but I thought i would share a picture of my 2.5 year old LiFePo4 48v 12amp battery repaired abused and pushed to destruction by my modded 1000w DD Ebay motor kit ImageShack Album - 14 images.
No fires or venting from the pouches has ever happened with these cells, just as well as i use a backpack.
These cells are rated as a 2c (24amp) max discharge they were being pushed to nearly 4c (40amp+) by this motor kit. but still lasted 1.5 years with this setup.
30,823
Didn't they do well Andy!
Was this a Li Ping battery or another ebay one that was with the kit?
aaannndddyyy
304
9
63
Norwich Norfolk
What's the difference between the two versions and is the latest much better?
My v2 had the 4amp pouches with smaller tabs and as earlier BMS without the lights, V2.5 has 5amp prismatic cell with bigger tabs and the newer BMS has the balancing lights, the battery is packaged a lot better feels more robust and solid.
The 20amp cells are a much better size for the higher wattage motors, I use the V2.5 with an X5 motor which is still asking a lot from a ping but the cycle annalist keeps the battery in check,
My v2 was used for my 250 watt Ezze motors and if I hadent gone to higher powered motors controller I have no bought the battery would still be ok today.
morphix
2,163
119
Worcestershire
www.cyclecharge.org.uk
Nice write up with pics and stats too! Good to see an eBay kit reviewed... I've seen that seller offering those 1000w kits for a long time. I bet that is fun to ride at those speeds too! That's approaching moped speeds. I can only get those speeds downhill, pedalling like crazy with a strong tail wind :D
