Hi just wondering how does the bike know your doing 15MPH and limits your max speed to that sorry if thats a daft question.
Davie
Davie
Yes, that's the one.the voltage provided by the battery and the voltage that is generated when the hub rotates. When these voltages are equal then the assistance stops. When my hub was in the wheel this used to happen at about 15 mph. Now its not in the wheel its more like 25 mph.
ps - I think this is the second method as described by flecc.
A simpler way with wheel speed sensors is to shift the sensor to the frame by the chainwheel and mount the magnet on the chainwheel. Since the chainwheel turns much slower than the wheel in top gear, the cutoff speed is multiplied.It just occurred to me that if you wanted , you could increase this speed in the following way . Disconnect the sensor , which I am assuming is a magnets and hall effect affair , and replace it with a simple pulse generating circuit based on a 555 timer chip . Incidentally , my bike has a "power only " option on the ignition switch . So is this still legal ?
If you're lucky, you can just remove the magnet. Some controllers, like the Tonaro's one, only limit the speed when the maximum number of pulses is reached. Zero pulses is less than max, so that's OK.As I have said before , I am new to electric bikes . My ancient Powabyke has a pedal sensor built inside the bottom bracket ,and also a wheel sensor mounted on the left side of the rear hub . This looks a bit like the band brake you see on kids electric scooters . So presumably this is what controls the speed at which motor assistance is switched off . It just occurred to me that if you wanted , you could increase this speed in the following way . Disconnect the sensor , which I am assuming is a magnets and hall effect affair , and replace it with a simple pulse generating circuit based on a 555 timer chip . A potentiometer could control the pulse rate , and fool the bike controller into thinking that the bike was traveling a lot slower than it really was . You could use the same idea to replace your pedal sensor if you did not want to peddle .As it happens I am quite happy with speed of my bike . Incidentally , my bike has a "power only " option on the ignition switch . So is this still legal ?
If it's a wheel sensor and magnet like the one I described above, you'll see it of course, they're usually on the back wheel. If not and your bike always has exactly the same cutoff speed as the battery content declines, it's limiting set by the controller. If the maximum speed cutoff reduces as the battery charge declines, say from 16.5 mph to 14.5 mph for example, it's the second type I mentioned which works as kitchenman described.How do you know what type of sensor your bike has.
Davie
