Best seller for the Bafang BBS01B?
sparkysx
145
Hi,
I've decided to get a legal 250w 36v BBS01B, but am struggling with who to buy it from.
Yosepower don't have any in stock, pswpower do but they are based in china and ship from berlin, they charge £300 delivered but if it goes wrong you have to send it to China.
MAF scooters do it for £345 delivered but I don't know which display it comes with, really I want the 965 display.
Eclipse bikes charge £345 plus postage which is nominal, but I worry about getting hold of them if it goes wrong as I have heard on here they are tricky to get hold of?
Any other suggestions or experience of the above would be greatly appreciated.
thankyou
wheeliepete
2,047
757
Devon
Eclipse can be a bit slow to respond, but do get back to you, prob quicker than any chinese vendor, apart from EM3EV, who are excellent, but no longer sell the 250w. Woosh sells the BBS01 with various battery options and his CS is spot on. Everybody is looking for the best deal they can get, but you must realise that warranty and good CS are not free, they are built into the price you pay. £300 from China and you are on your own, £379 from Woosh with all the help and assistance you need plus a warranty that you can call on should you need to.
8,750
Simples get one from Woosh bikes or opt for the TSDZ.
If you want the very high torque 25a ETM version look at Brighton ebikes.
Reactions: wheeliepete
17,225
I emailed woosh several days ago, but they haven't responded.
I always responded within a day.
what was the subject line? I can search my mailbox.
Are you markry*?
Reactions: sparkysx
danielrlee
1,399
725
Westbury, Wiltshire
torquetech.co.uk
Hear hear!
There's no way around the fact that good customer service & support costs money. Cheap(er) prices usually means means corners have to be cut. Be careful not to be penny wise and pound foolish.
Reactions: sparkysx
wheeliepete
2,047
757
Devon
Is the TSDZ better? I'd love the ETM version, but it's quite dear!
From what I've read, the TSDZ2 drive sounds like a nice, well built unit, although i havn't tried it myself. It's 48v and torque sensored, so similar to the bikes you have tried. Woosh has only recently started selling it, and I think he's quite careful in his selection of products, which suggests to me that it's of good quality. There's a long active thread on Endless Sphere about it's real time use.
https://endless-sphere.com/forums/viewtopic.php?f=28&t=79788
I think the BBS ETM is a BBS01 with a BBS02 controller and poss. motor fitted to it, although i can't be sure. Make enquires with Brighton Ebikes if it's of interest to you.
minexplorer
532
93
56
Four Lanes,Cornwall
Hi,
thankyou
eclipse warranty support is good.i had a throttle play up from rain.replaced straight away.controller issue from the wet throttle.sent in, tested and replaced along with the bus cable that developed a fault.
my 52volt shark pack 5p14s (70 cells) means u cld cram a 7p10s 36v in one of those, so id advise that if you can afford.if u get the 3500ma panasonic GA cells thats 24.5AH ! Those cells will not get anyway strained at 15amps in a 7p. you can run around all day on max assist with 100% 'keep current' programmed ,an never lose that big grin.
  • Disagree
Reactions: Ken J
sparkysx
145
all good advice, I'll probably go with the bbs01b as the TSDZ2 seems quite loud. How are the bbs01b's when you pedal, what does it feel like compared to a bosch or the rear suntour hub on a carrera crossfire I had?
thanks!
sparkysx
145
probably a 36v hailong 13ah, unless I go with Tony's Bafang 250w 48v hub kit, I'm undecided on whether to go with mid drive or rear??????? I like the idea that the mid drive kit could be put on a bike with any wheelsize, where as the hub will only fit a 26" bike.
minexplorer
532
93
56
Four Lanes,Cornwall
Yes its good to have a kit you can move from one bike to another. Remember it will come with economy programmed in.Depending on the vendor as to what but a virtual certainty the keep current will be 60%. Despite what u read it will pretty much be giving this all the time,not just when peddling at high cadence. So max PAS 15amps will really be 9.5amps.Buy a programming cable and the max capacity battery u can stretch to.You dont want to be constrained from enjoying full potential because u cheaped out on the battery.A lot of these guys claiming 1000 mile range from a 10ah battery are strong riders using low assist .
sparkysx
145
I'm just going to being using it round town most of the time with the occasional trek out into the countryside, 30 miles would be the absolute most I would be doing. Which battery would you suggest, I only really like the bottle shape and hailong shape, don't want some massive thing.
thanks!!!
17,225
I recorded the sound of the TSDZ2 for you.
It's quieter than the Bafang BBS01B and BBS02B. The TSDZ2 motor is smaller but spins twice as fast (Bafang 2000 RPM, TSDZ2 4000 RPM).
Reactions: sparkysx
