CARRERA VULCAN E 2017 BOTTOM BRACKET
Baz the balloon man
556
32
Oh I see so they are older probably better too if they are like the original Bafang model Vengeance .
I am not an expert on bike brakes but wonder if there is a service kit for these brakes like we used to service classic car brakes .
If not strip down clean and lubricate . Check any rubber seals you can see to make sure they are not perished then put them back together and change and bleed with new oil.
I just put some of the BMS boards in an air tight container to soak in Acetone I will leave over night and then clean .
Are you sure it’s ok to clean them in hot water afterwards will it not start corrosion on the components ?
I was going to use a soft brush and just put some rubber gloves on and gently clean then let the chemicals evaporate.
IT WOULD BE GOOD IF SOME ONE WAS TO COME IN HERE LIKE DAVID ON THE ANTIQUE’S PROGAM ON THE TELLY LOL
SOAR IN LIKE AN EAGLE
Baz the balloon man
556
32
Clark’s do spare parts I assume they are service parts too .
Strip them down clean and lubricate them check for any perished seals change if you can get new seals.
Change the oil and bleed them .
Park tools on U tube do some good bike mechanics videos have a look on there.
Or just hunt around till you find some new ones I will keep my eye out for you at the auctions.
I have just put some of the BMS boards into Acetone to soak over night in an air tight container out in the garden.
Once softened I was just going to clean with a soft brush and let the acetone evaporate.
Are you sure it ok to clean them afterwards with hot water will this not start corrosion in some of the components or are they made from non ferrous metals ? It’s not something I have ever considered doing
