Thanks Dave, notedI thought the plug was not fitted so the the wiring could fit through a small hole, lol
When you do fit the plug then just copy the colours on the socket side, red to red and so on
Carefully matched the pins (first time I fitted one of those connectors, was a bit nervous and thought it would be a b*tch) they went in easily..pushed them home with a little jewellers screwdriver until they clicked... and then fired it up, this time with one end resting on desk and the other end held securely in a pair of pliers to try and keep it levelI thought the plug was not fitted so the the wiring could fit through a small hole, lol
Heh..it just doesn't look right or suit my taste. It's got to be black or nothing.Fit it.. Use it
Black & Silver is classy![]()
Ok blackening sounds good... if you have a link that would be grand..The Q100 is silver as well, lol
I suppose I could take it off your hands for a few squid
Did you read my edit above?
Time savingI'll find a link now..
You'll let it go at cost, so where's the incentive to buy, lol
Thanks Dave..it might be ok just for doing some photos and videos as a prototype..as I'm trying to sell the concept of an eMezzo to the manufacturers.Birchwood Casey ALUMINIUM BLACK Metal Finisher | eBay
The finish will be not be as good as sending the wheel to have it coloured by the hot acid method ... But
Just respoke the front hub into a silver rim to get a matching pair. You'll have all the spokes and hub already so it'll be a doddle and there are a few shops will true the built wheel for very little. Or blacken the rear one as Old_Dave suggests. If you go out on these filthy roads at the moment, your rims will be black with dirt in no time at all anywayHeh..it just doesn't look right or suit my taste. It's got to be black or nothing.
I've got a couple of their 16" rims, but they're a different size to the Mezzo/Dahon ones (Chinese inches instead of English).Oh dear... Oh dear
Just looked at my BMS supplied ready built Q100 wheel and it's ...........
Lol
