Here's a photo. It looks about 18-20mm. I'm not at home at the moment, so can't measure it. Because it's removable, it's easy to grind it to any size you want.'The Cute motor has a removable bush'
Dave, I didn't know that - do you know what width you get with the bush removed?
Alan
Eddio, I said it was the perfect commuter bike because it's small enough to be carried on the bus, tube and groceries but also fast enough to be ridden as a normal bike. This bike doesn't fold as small, but it is WAY FASTER and easier to ride. It is however not as efficient as a normal road bike.I though the Brompton was the perfect commuter bike, this looks a bit heavy to me......
Thanks, do you have any idea where I could find such as trustful engineer? I think I'll probably need to ask him to make sure the rear magnet can be fixed to the shaft appropriatly:Hi Chiwah,
If you decide to go with an eZee motor, I agree with D8veh, turning back the 'shoulders' on a lathe by up to 10mm would solve the problem and that would still leave space for a Freewheel, but that is a job for an engineer and one you can trust.
You may be able to stretch the rear forks by a couple of millimeters without too much effort so that the shoulders only needs to be reduced by say 8mm. But as they say in carpentry, measure twice and cut once.
Dave, do you mean this part is removable?Here's a photo. It looks about 18-20mm. I'm not at home at the moment, so can't measure it. Because it's removable, it's easy to grind it to any size you want.
The Brompton M3L comes in at 11.5kg as well. Remember too the Brompton has a steel frame. The Ti version (very expensive) is 10.5kg.This bike is also 11.5 kg. So it's lighter than a Brompton. But it folds indeed bigger.
You've marked the nut. The bush is on the shaft between the nut and the motor. Both can be removed which will shorten the width on that side by about 25mm.Dave, do you mean this part is removable?
Removing the bush might be a good solution ig the q128 has one. Need to study photos. Also, it might make the wheel more central.Dave, if I get the Cute128 with 145mm dropout and that I remove completely the brush (25 mm), I'll end up with a 120 mm dropout?
I can then just plug a single speed freewheel and that's done?
Jerry, I agree the Brompton seems to be a beautiful bike. I may get one in the future if this bike doesn't fulfil its function
That was only an image of the calculator, here's a new one below that I've copied for the 53/13 tooth combination:Flecc, I just realised I did a mistake on the chainset turns, it's not 57 but 53T
How do I read your chart? How could I know what is a normal RPM for a human peddling?
