Is an Electric Mezzo possible
birthstar
I have bought a Mezzo Mezzo Folding Bikes and have been considering adding some power to help out with the hills around Bristol.
So far I am coming to the conclusion that with its super folding bits getting in the way I am going to find this near impossible (I am looking to put together a front hub set up with a throttle).
I have read there exists an 80mm Tongxin motor which I think might squeeze into the space but I was not able to find dimensions of it on the Tongxin website. The two dimensioned drawings I found both look about 101mm wide for the front fork options.
Any pointers out there? Any helpful ideas would be nice too:D
jerrysimon
3,292
112
Cambridge, UK
daniel.weck
1,229
jerrysimon
3,292
112
Cambridge, UK
Dan I am not sure if that is too large i.e. not 80mm like the Tongxin ?
Regards
Jerry
daniel.weck
1,229
Thanks!
Is this is 80mm motor? http://www.tongxin.net.cn/en/down/dianji2.jpg
From the various photos of installs I have seen it seems that it is not possible to use quick release skewers with the motor (these are required for the folding mechanism on the Mezzo). Is this correct?
I would not use quick-release nuts with hub motors.
Some close-up photos here:
http://www.pedelecs.co.uk/forum/electric-bicycles/4682-diy-stage-1-received-bafang-tongxin-kits-photos.html#post59187
and here:
http://www.pedelecs.co.uk/forum/electric-bicycles/4747-diy-stage-4-16-wheel-lacing-building-photos.html#post60154
30,805
Thanks!http://www.tongxin.net.cn/en/down/dianji2.jpg
Yes, quick release skewers are impossible with any existing hub motor, some having cable entries within the spindle and at least one having a two section spindle. The motor torque is such that the spindles have to be very firmly clamped into the frame with full nuts, and in many cases anti-torque arms are fitted as well.
birthstar
Thanks flecc, in that case it seems that the answer for the Mezzo is not if you want to keep the ability to fold.
daniel.weck
1,229
