Kettle-plug power connector alternatives?
morphix
2,163
119
Worcestershire
www.cyclecharge.org.uk
I don't like the fact that BMS Battery puts kettle plug connectors on the charger, batteries controller and mains lead. This makes no sense to me and presents serious safety issues. I recently connected my mains socket lead directly into my battery by accident! Luckily no damage was done as the mains box tripped instantly.
Does anyone know of a safe alternative male+female connector set for carrying 10A to the controller from battery? Doesn't need to be waterproof, but does need to be fool-proof (i.e. only one way to connect and no protruding pins).
I'd also like to put different connectors on the charger-to-battery, so that I end up with only ONE kettle plug lead being used from mains socket to charger. This seems a much more safer and sensible approach and avoids any confusion.
Would welcome any suggestions!
cwah
3,048
179
www.whatonlondon.co.uk
For 10A current, a good foolproof one is the EC2 connectors:
EC2 Female & Male (5pcs/bag) (UK Warehouse)
They are small, with strong connection and last long time.
The only issue is that you need to solder them. I would prefer crimping but I haven't found reliable crimping connectors (anderson powerpole connectors get loose over time)
KirstinS
3,224
899
Brighton
I really like xt60 connectors - foolproof, solid connection, up to 60a I belive, also watertight
horses for courses though I guess !
You can use virtually anything for the charger because it's only about 2.5 amps. For power wires, I've standardised on Deans, because they're very easy to solder onto the leads. I've tried other ones, but I can never get the pins into the housings. I always have to file every one to get it in. Maybe there's a special technique.
Don't forget that you should always put a female on the battery to avoid live bear prongs.
For charger:
Pk of 5 x DC Power Plug 2.5 x 5.5mm Male & 5 x Matching Inline Female | eBay
For power:
Deans Connectors T Plugs 5 Pairs With Heat Shrink | eBay
morphix
2,163
119
Worcestershire
Thanks guys, I'll get shopping ;-)
I usually use bitsbox.co.uk for my bits and bobs, or eBay.. but I also have a trade account with RS Components that offers free delivery and no minimum order, so if anyone ever needs anything from there, feel free to ask, I'd be happy to order for direct delivery to anyone.
Streethawk
634
16
Also Deans are what the majority of RC folk use, they're just rock solid reliable.
103Alex1
2,228
67
Yup ... Deans on the battery to controller lead interface (battery side)... I use Anderson Powerpoles on the controller side). I use Neutrik XLR for the battery to charger connector and Anderson Powerpoles on the controller to motor phase wires.
jerrysimon
3,292
112
Cambridge, UK
Big Deans plug connector fan here for the last 4 years of ebiking. If I was starting again I would look seriously at xt60 connectors though.
Too much hassle to change them all over now.
As others have said comes from the RC hobby from which I spent many years in.
Ps it goes without saying that when using Deans you use the female on the battery not male where it can easily short!
Jerry
103Alex1
2,228
67
I bought some of those and was looking at changing the Deans ones when I rewired everything. But having test-soldered a couple onto a length of wire decided the Deans ones seemed better and neater. You can get them with ribs on for extra grip when connecting/disconnecting - I like these much better.
Gringo
1,352
843
Northampton
XT60 every day
I'm big into RC and over the last 12 months I have been upgrading from deans (so last year ) to XT60's
I've done 6 speed controllers and to many lipos to count !
What finally convinced me to change was Hobbyking, I was getting more & more new battery's with XT60's fitted as standard and now there's no going back, easier to use and a better connection (IMO)
I'd put deans on my nicad's :D
XT60-----the new industry standard (unofficial)
103Alex1
2,228
67
XT60 every day
It's very funny reading the hot debates on connectors on RC forums. I thought XT90s were the new industry standard ... :)
