Help! My next project
Benjahmin
2,726
1,793
71
West Wales
Well tight wad has won out, so I've decided to go with what I've got.
First was scavenging the rim from a defunct Ezee motor case:
Having removed the spokes I've used the Ryan method of finding the ERD. I tightened nipples onto two old spokes so they would not move. Cut off the j bend and cut and file the spokes to the same length. In this case215mm. Insert the spokes into opposite holes and measure between the two ends, 172mm. Then add the lot together to get ERD, 215+215+172= 602.
Next stop will be Grin Technologies site to remind myself on how to measure the hub motor to get spoke length and offset.
So to spokes and the much debated 'What diameter?'. Remind me is it 12 or 13 guage? I favour Sapim super strongs if I can get them.
3,971
That's a lot of work to get a simple measurement. I just measure the diameter in two directions and add 5mm.
harrys
403
108
Chicago, USA
"Having removed the spokes I've used the Ryan method of finding the ERD. "
I like that method. I have some straight spokes that I bought by mistake. Would be a good use for them.
On my last wheel, I used the ERD on the seller's website. Normally, I don't mind if they are a bit long, because I use double wall rims and can add washers too. These .
spokes were so long, they poked past the upper wall.
Benjahmin
2,726
1,793
71
West Wales
The Grin spoke calculator is giving me left spoke length 241mm and right 240.1, so I'm thinking 241 all round.
3,971
Well there ya go. Experience wins out. Sometimes you've just gotta do it the hard way to see the easy way !
What about you try it my way and see if you get the same result or how close it is? I've never done it the proper way so I'd be interested in whether there's any difference.
Sturmey
729
383
68
........ Remind me is it 12 or 13 guage? I favour Sapim super strongs if I can get them.
Looking at your hub in the spoke calculator you posted above, you have a large dish/offset of 9mm and a spoke tension ratio of 32:68. I would use the lighter 14 gauge rather than the heavier 12 or 13 gauge as there wont be enough tension on the disc side to properly tighten the heavier spokes if you use them.
Sturmey
729
383
68
Yeh, definitely leaning towards single butted, so 13 g at the hub down to 14g for the spoke.
The picture below helps to explain why 14g at the j bend may be stronger than the thicker 13g. When the spokes are newely fitted, there is a gap at the spoke flange. With the lighter and more flexable 14g spokes, this gap disappears when the spokes are tightened and pre-stressed ( checked and re-tightened if necessary). Those stainless steel 13g j-bends spokes are very stiff and have difficulty bedding in at the j bend. This means that there is movement and eventually fatigue at the j bend. This in my view explains why the lighter 14 g spoke may give better service and why I would keep away from 13g (even butted) if possible.
63372
17,308
If you spoke a wheel traditionally from scratch with 13 or 12 gauge spokes, you will notice that at the beginning, there is noticeable friction between the j bend and the flange of the motor and also the angle between the nipples and the rim may look uneven. I usually stop several times when tightening the nipples, take the wheel off the truing stand, put the wheel on top of my trusty bin and push the motor up and down several times to loosen any j bend that may not sit well in the flange of the motor. I give a squeeze where two spokes cross to make sure that the nipples are also centered. Flip the wheel over and do same fir the other side. That adds 5-10 minutes to the build time but it's well worth the effort.
Benjahmin
2,726
1,793
71
West Wales
I see what you're saying but this is taken care of by having the left side spokes (non drive side) with the bend on the inside of the flange, and the right side on the outside. Whilst reducing the triangulation of the spokes to the rim it helps to bring the tensions nearer together.
Grin say that they 'recommend to anyone who will listen' that you use butted spokes with 13g at the bend and 14g at the nipple, for hub motor builds. This also allows for the flange holes of my AKM measuring a consistant 3.2mm with the calipers.
We'll see, if I break any spokes I can come back and say, 'You told me so !' .
I agree, it's amazing how much squeezing, bending and flexing goes on during the process. Even spokes that get bent during lacing end up pulling straight.
17,308
It is good to use 13g at the flange and 14g at the rim but those spokes cost a lot more compared to ordinary stainless or anodised 13g for your AKM, especially if you have to buy singly at a later date.
Benjahmin
2,726
1,793
71
West Wales
True, but what with the motor, battery and panniers full of shopping I'll be asking a lot from the spokes.
Anyway they're now ordered for £31 inc. nipples and delivery. Considering I'm using a rim I've had lying around for ages, that's not too bad.
3,971
For comparison, my 14g plain stainless steel spokes cost £9.99 from Amazon. They'll be carrying my weight (100kg) + up to 10kg of shopping.
Benjahmin
2,726
1,793
71
West Wales
Ouch ! I guess I've paid the price of obsessive over engineering.:rolleyes:
In my defence, for various stoopid procedural reasons, I can't use Amazon. I've tried, I'm blocked.
17,308
each spoke can hold as much as 200kgs in traction force, so what gives first is not the strength of the spokes but something that caused the spoke to be loosened like the hole in the rim gets damaged or the spoke gets broken at the J bend. It is rare that spokes break in the middle. When the nipple is so loose, the spoke gets put into compression and snaps. It follows from those observations that the tension needs to be even to distribute the load evenly over many spokes, the nipples should not be too tight that may damage the holes in the rim if you hit a pothole but tight enough so they don't get loosened. I use a drop of linseed oil to help the nipples from getting loosened.
Reactions: Benjahmin
3,971
Failure mainly comes from metal fatigue in the elbow as a result of not enough tension in the spoke. When you put weight on the bike, the lower spokes go into compression, which puts a bending force on the elbow. 14g spokes are more elastic, so it's easier to keep them in tension all the time, which is probably why I've never seen an elbow break on one. I've seen plenty on 13g and even more (proportionally) on 12g, which is not the result that most would expect.
If ever you hear spokes creaking, it because they don't have enough tension. You must solve that quickly otherwise you'll be finding broken spokes at the elbow.
Reactions: Benjahmin and Woosh
Benjahmin
2,726
1,793
71
West Wales
Finally got all the bits I needed and the time . So, in the spirit of 'show us the pictures or it didn't happen', here's the build.
Motor labelled and ready to go:
Build went smoothly despite some brain fog:
Had to build a front wheel too with a new hub. I've really enjoyed the wheel building process, pity I waited to my seventies to learn this skill. Both wheels ready to go:
I ended up having to swap the bottom bracket for one with a longer spindle to accomodate the pas. Handlebar layout took a few goes to get everything to fit.
The bike fully loaded.
Now a couple of questions.
The reason for doing this was to end up with a fully legal bike. The motor itself is labelled. The bike isn't - yet. I know it needs to state the speed limit and also the manufacturer, but who the hell is that? AKM (the motor), Carrera or me? Does it need anything else?
Second question is a set up one. The display is programmed to give walk assist throttle until pedals are turned, then it gives full speed. Great ! Only thing is full speed throttle continues after pedal rotation ceases and only reverts to walk assist when throttle is released the operated again. As I understand it to be legal it should revert to walk assist as soon a pedals stop. Anyone know the setting, the Chinglish is doing my head in?
