Old Giant struggles with hill.
3,933
You've all been very helpful so far, thanks.
Re. Cabling: I'm competent with a soldering iron etc., so while I don't mind too much about cutting and splicing cables for PAS etc., I'd prefer to leave the 9 way Julet motor connector as is, so looking for a mating cable. I seem to be able to find plenty, but they're only 600mm long, which won't reach from the controller, which is between the seat down tube and the rear mudguard, to the front hub. Any idea where I might find a longer cable, without breaking the bank?
Also, I'm hoping that the LCD5 display I ordered comes complete with cable, but it's hard to tell from that Pswpower web site.
There are loads of people selling motor cables of every type and length on Ebay.
Peter.Bridge
1,684
757
This is how it looks on PC, I don't know how t looks on Android, iDevice etc... they've got controller descriptions in the "Alt" tag of the images, which only appear when you hover over them with your mouse pointer, and what you've selected for "SKU" only appears above after you've selected an image.
Its really confusing on Android because you don't see the alt text when you select it, but after you have selected everything it shows it
3,375
There's no "MouseOver" equivalent event to program for on Android, but if you press and hold on the controller image, the ALT text pops up. Mobile devices have ruined the internet.
jarnold
70
12
72
Gloucestershire
Holy cow! The controller arrived today! Complete with a throttle I don't want/didn't order and a PAS that I don't want/didn't order, and a cable that doesn't seem to be if any use. Sadly, the motor cable will probably take much longer in transit.
Reactions: thelarkbox
jarnold
70
12
72
Gloucestershire
So...I guess the throttle will be useful for testing, and I might replace the PAS that I already have, even though the sensor is epoxied to the frame...
However, I'm slightly dismayed that there appears to be no "learn mode", so I'll have to try 36 different permutations of phases and hall sensors, unless there's a shortcut or trick?
3,933
If you have a KT controller, you can have a legal throttle with P4 =1 and C4=3. That way, the throttle gives 4mphwhen not pedalling and 15 mph when pedalling. It works like a boost button. You ride along at level 3 or whatever you want, then when you press the throttle, it goes immediately to level 5 to boost you across crossings, round roundabouts and up short hills. When you let go of the throttle, it goes back to level 3 - much easier than working your way up and down the buttons.
Reactions: Peter.Bridge
jarnold
70
12
72
Gloucestershire
Interesting.
Any insights on sorting the phase and hall connections? Further reading suggests it might not be necessary to go through all 36 permutations, but you guys seem to have a lot of experience.
3,933
Interesting.
36 combinations of which 3 will work, so the chance of getting it right first time is 1 in 12. And you should get it within 12 tries. If it takes you 33 tries to get it right, buy a Euromillions ticket for tonight because it's over £125 million and you'll be due some luck.
jarnold
70
12
72
Gloucestershire
Sadly, luck doesn't work like that.
jarnold
70
12
72
Gloucestershire
One more thing, while I wait for the motor cable to arrive: I think I'm right in saying that I will need to keep the spoke magnet and sensor, as the hub motor has a freewheel?
That being the case I will have to move it from the back wheel to the front, so that I can break out the wires for it.
The supplied(but not ordered) PAS has a captive rotating part, and no means to mount the stationary part, apart from the cable. Are these reliable, or do they wear out quickly? I'd like to use it to avoid having to bugger up the nice neat wiring loom, and because I would hope that it's compatible with the controller, even though I've had no problem with the existing one, I have seen threads on here from people who have.
jarnold
70
12
72
Gloucestershire
Well, the motor cable finally arrived (Thanks, Evri...) and it's no bloody use at all! I now have two female connectors, which I find totally weird.
So I'll just cut the cable and solder things. I'd hoped to have a neat, removable solution, but obviously the universe had other ideas.
jarnold
70
12
72
Gloucestershire
Finally got the phase and hall effect connections sorted. Note to self: Don't assume the black wire is ground - it just could be the screen, and the black wire is redundant... That wasted a fair amount of time! The LCD kept saying E03, but I assumed that an incorrect hall sequence could give that, so it wasn't until I got the meter out that I realised I had no ground continuity.
Now need to do a proper job of splicing the relevant wires together, and try to devise a method of physically fixing the controller to the frame.
jarnold
70
12
72
Gloucestershire
Hmmm. It's a lot better than the Brainpower controller, but seems to cut power at about 11.5 mph, even though the max speed is set for 25kph.
Any insights?
jarnold
70
12
72
Gloucestershire
Sounds like the P1 setting is out.
That's the conclusion I've been coming to, after more reading. The speedometer reading is, I think, correct, but that comes from a spoke magnet sensor. Is it possible that the speed limiting is independently controlled by the P1 setting?
My P1 is currently 87, am I right in that I would need to increase this to get to the 15mph limit?
3,933
Any insights?
Set P1 40% higher. As I said in the other thread, the actual speed limit comes from the hall sensor pulses. The controller calculates the speed from the wheel size, reduction ratio and the number of magnets in the motor. The displayed speed comes from the speed sensor pulses, number of magnets in the speed sensor and the wheel size.
Sparksandbangs
104
36
I was going to say try around 115 to 125. Completed guess based on the speed but someone with more knowledge has given you a better figure.
jarnold
70
12
72
Gloucestershire
Although I must have missed where you said that in the other thread.
3,933
If you set P2 to zero (number of magnets in the speed sensor, it'll use the hall sensor pulses for the speed display as well as the speed limit, but, of course, no speed would be displayed when freewheeling. I guess they use separate systems so that they can get the speed from direct drive motors without a speed sensor.
Also, as I said in the other thread, if you went a little higher on the P1 setting, the cut-off speed would be higher than the displayed speed and the cut-off limit shown in the settings.
